Took her on her maiden voyage after the body bushing swap. SO NICE! You know after a while you get used to a car and just believe that it is just the way car is? Well that is how I felt with making turns with this car...I'd always have to wait a split second until the body would follow the chassis......... Well that was all wrong all of those years. The car is a blast to drive (and corner!). Cut the wheel and everything follow suit simultaneously. NICE!
Was ending my trip and I began hearing chirping sounds from the rear of the car and LOUD ones at that. Turns out the speedway rear springs were slightly interfering with the washers for the new body bushings rotated the springs and we are all good.
What is also nice is that loud clunk/chirp from the passengers side front tire area is gone with the new bushings as well! I guess things will clunk and chirp when there is a half inch of play in the bushings.
Oh during my cruise I was coasting in overdrive at 60 MPH. I mashed the pedal and dropped the gear selector into drive. CHIRP goes the tires!!! WOW.
And Thain, I loosened the bolt holding the gear selector rods underneath the brake booster. It sprung right into place and everything fees normal again. Thanks.
![eek](https://www.grandmarq.net/vb/core/images/smilies/eek2.gif)
