Also, Gotta love that two tone.
nice cover!
i had a high end one that came with my 84 mustang svo, i was told it was over 300 bucks in the early 90's
This cover was $500! But for the amount of money I have into the car $500 is cheap insurance to give it some protection.~David~
cool.
It's funny, when you see it from the side covered, it's REALLY obvious that the tudors had basically (exactly?) the same roofline as sedans. It sounds crazy if you look at a tudor alone from the side normally. As soon as you can only see the profile, it's obvious.
Yeah its the same damn thing. I had to argue with the salesmen from JcWhitney about that.~David~
Had the car cover on for a long while now. Had to have been about a month and I cannot express how pleased I am with it. It has snowed and rained between then and now and underneath the cover lies the car just as I left it, minty fresh after its hand washing and wax job. Simply amazing. Not one spec of dust or dirt and absolutely NO water got though it. Again I purchased it though JC Whitney and it was the COVERCRAFT WEATHERSHIELD HP CUSTOM FIT OUTDOOR CAR & TRUCK COVERS.~David~
nice, thanks for the update. might look at getting one. GMGT might have to sit outside next year, so my 30 dollar cover wont cut it lol.
No problemo Julian. It is awesome when it is raining on the car with the cover as the water flows right off of the material.~David~
thats it, most covers are water resistant, not water repellent.
It will change a bit after it has been out in the weather for an extended time. the water will not bead and run as at originally did. It is actually impressive the water looks like ice.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Cover is still doing well. Speaking of cover I removed it today to move the car around into the back yard (street is getting torn up tomorrow) and I did a brake stand and the clutches are dead in the rear. Pitiful one wheel peel. I see 3.73's clutch kit and a rear girdle in the Brown Blobs future.~David~
Yes! If you got access to a lift, paint the rear axle. It'll make the rear girdle look more impressive.
I did that to my CV and looking from behind (plus the exhaust), it's beginning to get the reputation that the Malibu had, except people know better this time around. Which will make it all better when I put something under the hood that will actually run. LOL
BTW, how was New Years? Did you steal a kiss from J McCarthy or did you run away? I hope you chose the latter as she scares me.
not much point in that unless you have enough motor in front of the rear to actually risk some damage. A lopo ain't there.
Putting together a parts list to finish rebuilding my Stromberg-Carlson amplifier. Its got enough parts out of spec that I've decided to just replace everything. It should cost me another $8 or something in components. Woo.86 Lincoln Town Car (Galactica).
She has a strange hair line but I'd tap that. lol
Good new years Jacob, Thanks. Smuggled a girl friend of mine onto the grounds around 9pm............I left Times Square at 3:30 when truck was packed with all of its gear.
I'd plan to paint the axle as well.
Thain. I build stuff for the future. Crate engine is saved up for ten fold plus already. Just a matter of when. Rear girdle wont hurt for the time being.~David~
