again... shiny
Thanks!
The car has not been washed since 2012.
She sits pretty under my car cover and just gets detail sprayed after every outing. Not bad!
Luckily this way I can keep the water away.~David~
Where did you get the splash shields? One of mine has been missing for years and the brakes are getting squeaky. Pads aren't bad but at this point I'm ready to change them and the hardware just to make it stop. I wouldn't be opposed to replacing those shields while in there.86 Lincoln Town Car (Galactica).
I found a really clean set at the junkyard.~David~
Nice!
I know I've said this before but might as well say it again. The LX sport wheels look perfect on your car. Not sure if it's the stance or what, but they're spot on.
Pulley looks good on there. I bet your heater core will be a much happier camper.
What's the story on tigger?1990 Country Squire - weekend cruiser, next project
Originally posted by Tiggie View PostI know I've said this before but might as well say it again. The LX sport wheels look perfect on your car. Not sure if it's the stance or what, but they're spot on.
Originally posted by Tiggie View PostPulley looks good on there. I bet your heater core will be a much happier camper.
David, got a question for you. Actually two questions. #1 are those Twisted Wedge heads? #2 do you think they were worth it, compared to say factory P-heads? I got an engine I'm about to assemble and the machine shop checking the P-heads out reported they will need new guides and a valve job, to the tune of about $450 (includes springs install and height set). Plus the cost of the pedestal-to-stud conversion kit, so like $600 total. Looking online, Twisted Wedges are $660 a piece so a bit over $1300 total. I'm wondering if it would be a good idea to dump the P-heads and go for the gusto right off the bat... Rest of the specs are Cobra cam, Explo intakes, MAF, Scorpion stud-mount roller rockers, maybe 24 lbs injectors to make use of better heads. With a T5 behind all of that.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Luckily this way I can keep the water away.1985 LTD Crown Victoria - SOLD
I have a restrictor in the inlet so it can only get better.
The tiger kinda came with the car when dad gave it to me. I think mom got it for dad or something.....Anyways it was in the car and I don't mind him.
Originally posted by His Royal Ghostliness View PostI'd say it's both the wheels and the stance. And yes, it does looks awesome!
I install reducer bushings in the upper hose whenever possible/feasible. It's just a steel bushing that has suitable OD and like 1/2" ID, nothing fancy. Figure if it's good for a low-RPM diesel (they have the barb fitting for the supply coolant hose machined that way from the factory) it's gotta be good for a Panther than can hit twice the engine speed.
I would go the extra bucks since you are kinda close to that amount already, if you have the extra coin.
If not you have kinda a stock combo (ford stock) so running the p heads cannot hurt too bad.
If the P heads did not need that once over ($) I would run them without hesitation for the above reason...stock ford combo so it should all work nicely.
Kinda not answering your question....Either way. If it was me and I had the money I would go big with the TFS heads. If the ford p heads were fine I would go with them.
Originally posted by DerekTheGreat View PostWhaat? You don't have to wash your car to get dust off? My car has gotten scummy since the meet up with dust and stuff. Do not want to wash away my Aerospace 303 stuff on my top.
I touch up the vinyl with 303 from time to time on my own car.Last edited by 87gtVIC; 09-18-2017, 01:47 PM.~David~
They went to metal in the later years. These are metal.~David~
I think 95+ are metal.
Originally posted by 87gtVIC View PostI would go the extra bucks since you are kinda close to that amount already, if you have the extra coin.
Kinda not answering your question....Either way. If it was me and I had the money I would go big with the TFS heads. If the ford p heads were fine I would go with them.The ones who accomplish true greatness, are the foolish who keep pressing onward.
