Sweet! Are you happy with it?
Past Panthers
NICE! How does it feel? I wish I had pulled a pedal assy when they were readily available. There are none left in the yards around here.
I want one. Can you tell any difference in power?1990 Country Squire - weekend cruiser, next project
Originally posted by Tiggie View PostI want one. Can you tell any difference in power?
Wow, this interior is spectacular. Really really dig it.1985 2-Door: CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, ASP Underdrive Crank Pulley, Bilstein Rear Shocks, Rear Lowering Springs, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Ford Racing 4.10 Gear, Eaton LSD Differential - I own the fastest CFI powered box to the 1/8th mile: 9.658@70.74mph
1991 4-Door (Dad's Car): Pro-M EFI, 306ci, Forged Pistons, Ford Racing Aluminum Heads, COMP XE264HR cam, Cobra 1.7 Rockers, Edelbrock Performer RPM 2 Intake, 30lb. Injectors, Custom 65mm TB/EGR Spacer, Pro-M 75mm MAF, BBK Ceramic Shorties, Custom Summit H-pipe, Walker Mufflers, Jegs Built AOD, Roadrunner 3000 Stall Converter, Ford Racing 4.10 Gear - Best 1/8th mile time: 9.76@72.03
Originally posted by Mr Bean View PostDo you guys have hydraulic clutch setups?
Originally posted by tjc78 View PostSweet! Are you happy with it?
Originally posted by mitymerc View PostNICE! How does it feel? I wish I had pulled a pedal assy when they were readily available. There are none left in the yards around here.
Originally posted by mitymerc View PostShould be a big difference, MUCH less parasitic loss.
Originally posted by sluggish91 View PostWow, this interior is spectacular. Really really dig it.
Originally posted by GM_Guy View PostSweet!
Originally posted by TecNickal View PostNICEEEEEEE!!!!!!!!!!! Good sound, and shift when you want to. Excellent!!!!
Exactly. Much fun.
Originally posted by packman View PostAlways love the sound of the Brown Blob! Who owns that box MGM? Nice to see you're not the only one with a box in that area.
Here is the set up for the curious ones:
Transmission:- Tremec Heavy Duty World Class T5 (M7003ZB)
- Tremec T-5 Bellhousing (M6392E)
- Ford Performance Heavy Duty 10.5 Clutch Kit (M7560A302)
- Ford Performance Billit Steel Flywheel (M6375C302B)
- Ford Performance Pilot Bushing (LRS-7600A)
- Clutch Fork Dust cover (LRS-7513AK)
- Ford Performance Hurst Billet Plus Shifter (M7210M)
- Hurst Chrome Stick (0090)
- Mr. Gasket Shifter Boot (9649)
- Royal Purple Syncomesh Fluid (RP-SCM)
- Double Hook Clutch Quadrant (LRS-7553C)
- Maximum MotorSports Clutch Cable (MMCL-11)
- Maximum MotorSports Firewall Adjuster (MMCL-3)
- Piers (p71c1@yahoo.ca) Clutch Cable Firewall Bracket (essential item)
- Custom Pedal Assembly with 1972 Mustang clutch and brake pedals
Everything brand spanking new out of the package.~David~
Ok everybody sing!
Row Row Row Your Boat
Quickly Down The Street
Merrily Merrily Merrily Merrily
Gas Prices Are So Cheap03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Past Panthers
Originally posted by tjc78 View PostYou know what I would do with that interior? I'd go modern on it...
Dark brown carpet, lower door panels and steering wheel/shrouds. Then light beige leather/vinyl on the seats, and upper door panels.
Kinda like my 2009 Genesis was:
[ATTACH=CONFIG]53894[/ATTACH]~David~
Some random pick of the 5 speed install. Did more work than picture taking...
The new trans:
The old AOD:
Some dimples in the floor I pounded from underneath to show me where to cut for the trans to fit:
The tremec T5-Z all installed in its new home:
Stick in no steering wheel:
Piers firewall bracket for panther cars..a terrible pic of it:
Awesome piece. MUST HAVE. I bolted it in two places along the cowling/lip of firewall to windshield wiper areas as well as a bolt through the firewall just above the steering column. I modified it a bit to suit my needs but is an amazing foundation to start with. Sucker is planted and provided a nice sturdy base for a firewall adjuster and clutch cable.
A current (as of April 12 2020) engine bay pic:
You can see my new moroso catch can just in front of the receiver drier.
Also installed a raptor performance single mode shift light in the drivers side middle ac vent for stealthy points.~David~
that brackets made a world of difference. it looks so much more sturdy. and still fits by the booster. thats an aero body master and booster, correct?Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Alesha - Black 1982 Mercury Marquis - 255ci 178K, full custom Kenwood and Infinity system, lowered, dual exhaust, LED all the things
Tangerine Dream - Orange 1988 F-150 Custom - 300 i6 82k, Ghetto sound system, 5spd, 2WD, #farmtruck
Does the firewall flex at all?
