    That has to be one of the cleanest engine compartments I've ever seen, especially considering the car gets driven.
      Some time ago I added black seat belt sleeves that mounted up to the rocker panel to replace the cracked originals.
      http://www.grandmarq.net/vb/forum/te...16#post1386216
      while on a junkyard trip this summer I came across a 1979 Ltd-s model that had really good condition black seat belt receivers with great condition black plastics.
      The plastics around my seat belt receptacles were replaced and painted to somewhat match by myself years ago but the color was off and the paint wound up not sticking well and they were cracked too.
      http://www.grandmarq.net/vb/forum/te...439#post898439
      This morning I went about adding the newly acquired black seat belt receptacles to my car. Came out better than I could have hoped.
      before:
      Click image for larger version  Name:	IMG_7348.jpg Views:	0 Size:	3.05 MB ID:	1392551
      during:
      Click image for larger version  Name:	IMG_7350.jpg Views:	0 Size:	2.25 MB ID:	1392548
      Above...from left to right
      Stock 87, stock 79 in the middle and my combination that I installed into my car on the right.
      Click image for larger version  Name:	IMG_7349.jpg Views:	0 Size:	2.21 MB ID:	1392552
      I swapped the inner press button and the chrome outer cover onto the 79 black housings/plastics and receiver.
      and after:
      Click image for larger version  Name:	IMG_7351.jpg Views:	0 Size:	2.17 MB ID:	1392547
      Click image for larger version  Name:	IMG_7353.jpg Views:	0 Size:	3.13 MB ID:	1392550
      Click image for larger version  Name:	IMG_7354.jpg Views:	0 Size:	2.63 MB ID:	1392553
      Click image for larger version  Name:	IMG_7355.jpg Views:	0 Size:	3.02 MB ID:	1392554
      and the black covers swapped into the stock belts with chrome backs
      Click image for larger version  Name:	IMG_7352.jpg Views:	0 Size:	2.42 MB ID:	1392549
      looks good to but the beat up plastics and crappy paint don’t do it for me.
      The black plastic receptacles now match really well with the black sleeves down at the rockers. Much happy.
        I wonder if the black receivers get less scalding-hot in hot weather and sunlight...
          Id imagine more, strictly because of the low albedo of the dark color.
            Black will absorb more light (heat) than other colors so it should be hotter.
              Looking good !
                How hard is it to take apart those buckles? I've looked at my own before, but couldn't find an obvious way to disassemble them.
                  Remove the buckle from the vehicle. Look at the bottom of the cover and try to pry up one corner. Usually one side has a bit of room to slip a thin flat head in. Put buckle in a vice with a set of rubber soft jaws and then from inside use that same thin flat head and tap on the backside of the tang and it will pop loose the cover.
                  you can see the tangs in the photo above on the black cover
