Now that we're all caught up on what's actually been DONE to the car, here's the plan for the future. I know I've been prattling on about plans for the future in here for a while, but I'm going to have somewhere in the neighbourhood of 5 thousand dollars set aside for this car by may, so it's all a bit more real now.
The Big Picture
For the forseeable future, this car will remain appearing bone-stock. There are a few reasons for this, but mainly the laws here are stupid, and the less I look like a hotrodder, the less the police will pull me over.
This will extend to the engine bay. I have purchased a used intake and new Duraspark-type ignition for a mid 80s F-series truck.
The intake is a four barrel, and in as-cast form made as much as 290HP in marine engines. It is cast iron (bad because it's heavy) but it has a ford part number and pretty big runners, while being low profile enough that it should fit under the hood.
T his will be combined with a rebuilt Holley 4-barrel in the 650CFM range. Vacuum secondaries, electric choke, all emissions equipment INTACT. It will be stuffed under either a modified version of the original air cleaner, or the similar dual-snorkel air cleaners on 4-barrel fox body mustangs, with the 5.0 HO script changed to 5.8.
The basic idea is to make this car look like a stock setup. Unless you know that the very oddball civilian canadian 351W crown vics came with a variable venturi only, you'd never know I'd changed anything.
But John, you say, this thing sounds like it WILL be pretty close to stock. all ford OEM parts, where does the performance come in?
Aluminum heads (probably Trick Flow 185 Twisted Wedge)
custom-ground billet cam (shooting for a relatively mild idle, 5300RPMish peak power)
BBK 351W swap headers
Mustang catted 2.5 inch H-pipe
performance mufflers (still have a few different thoughts on this)
Impala tails
Best-of-the-best supporting stuff for this, like header wrap, roller rockers, etc.
Tranny upgrades, at least a new governor and shift kit.
3-gauge oil pressure (?) - tach - water temp bezel that will slide out of site below the ashtray
I should be able to get all this done by may-june with the exception of the heads. I may end up putting everything else together and putting back my current heads, home ported. I would still go back in and put aftermarket heads on later.
The headers are, obviously, not going to look stock. However, it appears they just don't make the 351W-compatible downpipe anymore for these cars. This means that it is actually much simpler to use the headers, which are longer to reach down and fit up with any crown vic or mustang h-pipe. Thanks to Gadget (I think?) for that info. I will use some creatively done header wrap to somewhat cover them up, but they're emissions legal and nothing exotic, so I'm not overly concerned about it ruining the stock vibe underhood.
After all this is done, I will re-evaluate my rear gears depending on how the car drives and if I'm still driving as much.
I'm also still looking for all sorts of chrome. I am waiting for my mirror to arrive, but am still looking for stripless bumpers, and plenty of other badges, handles, etc.
I got a quote for my vinyl top: 400ish if I rip off the top and remove trim myself, and 800 for the shop to do it all. That's tempting. It's not obvious in the photos, but the top is VERY badly faded and cracked. It turns about 2/3 turqoise if I go more than a week or so without soaking it in Autoglym Vinyl Dressing.
The parts I've collected so far:
Duraspark II ignition box
351W truck intake, this will be ported as best I can
I'm all a bit new to this, by which I mean I've never done anything more complex than swapping two identical carbs by myself, so any tips, suggestions, etc. are welcome, as well as any offers or leads on parts I've mentioned here.
Thanks for reading.
The Big Picture
Impala tails
Thanks for reading.
