again, I don't have the tools for it. The easiest thing to do is borrow an impact gun.
My '90 LTD Crown Vic
I thought about that and was wondering how safe it was. cool.sigpic
worst that will happen is the ratchet breaks.
wheel drums are in the waysigpic
fuckin finally found a place and correct tools (bottom bolts didn't even want to come off with an impact wrench, it took some wrestling + the impact) to do rear shocks and springs
kyb gr2 cop shocks + moog variable rate cargo coils FTMFWsigpic
definitely. it's not as floaty, but the ride is definitely 'harder'.sigpic
hit the wrench with a big hammer
a BFH definitely helped out tonight.sigpic
Real tools for the win.~David~
Who tagged this shit with 'mail the man a camera'? Laughed my ass off.sigpic
installing my new Kenwood 6x9s today..don't know if the stock grill will cover them, I doubt it. I'll figure something out.sigpic
if you mount them below the rear deck (in the trunk) they should fit without issue. This is assuming that the new speakers have the spacer ring on them to keep the surround from banging the edges. If the magnet is too large to fit the "giant rubber band" on, then you may have to use some baling wire or something similar to tie them up using the stock hooks. You could also mount them below after drilling the needed holes and just nut and bolt them in (bit more PITA, but it would work).
