Sly's Panthers
    Sly's Panthers
    Pics of my rides and the Home Depot special K&N intake on the 88 MGM.
    lol that intake is almost exactly what i was thinking for my wagon lol
    Ont And Canada PPL The Cookhouse in Dwight
    91 Grand Marq . . . . . . 88 ho wagon (project) . . . . . . 80' Lincoln Mark VI
      Love the window sticker lol
        Post more pics at your leisure
        '79 Continental Town Car
        '90 Crown Victoria LTD
        '94 Crown Victoria
          What is that sitting behind your alternator?
          Save a seal, club a liberal.
            Coolant reservoir.
              Coolant reservoir.
              what he said. I cut the washer/coolant tank in half and left the washer side in the corner to allow the hose access to the grill area. Got that aftermarket tank at the auto parts hut and hooked it up on the old platform for the original air box.
                yeah thats pretty brave to put a cheapo coolant resevoir right on top of the exhaust?
                  yeah yeah, before mouthing off, take a gander at the design (note the wire frame) that keeps the plastic actually off of the air-box plate (yeah you can't see the bottom, but you can see the frame is designed to mount to a wall and hold the tank up). oh yeah, the original air box is plastic too... is that too close to the exhaust as well? probably not since it was fine when I took it out and it actually sits flush on that plate. It was the flex snorkel over the upper tie bar that fell apart (hence my redneck replacement in the first place). FYI: there's a quarter inch of gap between the container and the air box plate and then another 2 inches or so to the exhaust plus the wind from the fan keeping all of this cooler than the exhaust by a long shot. Now if it was sitting ON the exhaust, I could see your point. But as I already stated that it is sitting where the factory air box was, you point becomes invalid quick.
                    I thought it was the coolant reservoir, but I wasn't sure.
                      I like that intake. interesting design.
                        That's one way to ram air. I like it.
                          I was originally just going for fresh air intake, but then I figured 2 more bends wouldn't matter any and I might force some more air on the highway. It helped with gas mileage a little so I'm happy with it. Would probably be better if I could get an HO intake on it.
                            New exhaust on the 93 Crown Vic. stock exhaust logs to magnaflow direct fit cats and then dual exhaust with magnaflow mufflers installed by a local shop.
                            Vid:
                              Sounds good. Post some day-time pics, next time you have the camera handy
                              '94 Crown Victoria
