Glen's 89
    Glen's 89
    This is the old seats and door panels.
    New seats and panels
      1st electric fan and old wiring
        New fan, I moved the relays and fuse box to the other side and cleaned it up.
          This is the 3G alt.
            Front and rear sway bars, they are from a 90 cop car. The 1st of the rear is with the drum brake rear end, the 2nd is with the disk. The bar is lower on the 2nd.
              I love everything! Circuit breaker for the 3g?
                Ya, I used a circuit breaker for 3G. It just seamed to be a better way to do it. I do everything 2 or 3 times. The 1st to get it in and see how it works, then change it to make it work better. Most of the things I change is just to see if I can do it or make it work better.
