I set up the attachments so that the seats can be set up in three different locations on the rail.
Creamy
Yeah, that can make a nice difference. I drilled extra front holes in my bench sliders since these Mustang seats have the flexibility of six rear mounting holes, and while they still ended up too tall, the ability to go a bit farther back did help.
You know something I just remembered? I always disliked sitting in the passenger seat when my Colony Park was completely stock, because the manual slider just seemed to put the seat up too high! Didn't have that problem with the dual-power-seat '79 Squire.Last edited by 1987cp; 10-10-2011, 11:48 AM.2012 Mazda5 Touring | Finally working on the LTD again!
What kind of paint did you use on the tranny?
Does it stand up well to gas\grease\heat?Thanks
Originally posted by mitymerc View PostDoes it stand up well to gas\grease\heat?Thanks
Once it is applied and drys you either sand it off as no solvent will remove it. It is a better version of POR paint. Brake fluid wont do much to it either. Typicaly when heavly coated with dirt road grime grease oil etc what dosent come off with soap can be removed with any solvent. I have sprayed don the trans with carb cleaner or brake clean as well as acitone thinnersScars are tatoos of the fearless
ok... that's pretty... want... but would so be wasted on my car.
Looks convenient ... but I don't see a swaybar in that picture?
Reminds me, I noticed today or yesterday that either a Trailblazer or Highlander or something similar had a Watt's link. Kind of surprising, compared to the days when wagons got no rear swaybar!2012 Mazda5 Touring | Finally working on the LTD again!
