Current update on the car.
Engine is still at the machine shop. It is already a month, but the owner has been good in answering all the questions I have had. Hopefully it will be done next week.
Transmission is completely disassembled and there are only two parts that are damaged. These are the sun gear and direct shaft. It is not that they are damaged but more of the line of having a lot of wear. A new direct shaft has been ordered from ford for $22. The direct clutch is already rebuilt. Only missing the reverse and forward drum. Need to order a new snap ring and piston for the forward drum because it doesn't seem like it will hold and the piston has a wear mark where the seal mounts. Will post pictures later.
