1992 Mercury Grand Marquis
    Tends to be a cycle of not posting so often. Graduated Electrical Engineering in May. Trying to get back on the Mercury Project. Got sidetracked because got an offer I couldn't refuse. Got a 2002 Mustang GT manual for dirt cheap because it needed a motor. Spent a month on getting it running. Since I finished the Mustang, I decided to continue the Mercury. I got a donor roof for it since the original roof somehow in the span of two years rusted by itself(I technically didn't attack it early enough, life got in the way). Good News is the project continues and should be close enough that I should be able to throw primer on it hopefully in a month or two hopefully.
    Here is the caranage.
    1992 Mercury Grand Marquis.
    Upgrades: Big Brake Upgrade, digital dash, Custom ignition Switch system, sequential tail lights, Teflon Fuel lines, LED interior lights, rear end rebuild with limited slip.
    Future upgrades: 5.0 swap, 4r70w swap, aluminum driveshaft.
      Congrats on your engineering degree. It takes A LOT of work - mine is in petroleum so I am familiar. Best of luck with the Mustang. That was a great deal of work on the Merc - looks good!
        Good work on the roof. Done the proper way.
          Congrats on the degree, and thats a fine result on the roof swap. Not sure I've ever seen the whole thing done before
            Thank you. Still more to come for both.
              Its my first car. Want it to be done so its dependable for many years to come.
                Thank you. Its been a process to have it installed. I've been going in blind getting it done. But its doable.
                  Well. Pulled the trigger and decided I want to do a manual swap on the car. Said to myself since the roof is replaced and the interior is still not in, might as well manual swap it now. Going with a tr3650.
                    Cool. I enjoy rowing my boat.
                      I like the manual on the Mustang. It sold me on the Manual transmission.
                        Transmission came in. Brought more parts than expected. Good news is I have an aluminum driveshaft and May install at the same time the 4.10s the old axle had.
                          Not much update but the roof is fully welded. I also did decide to go to bare metal to remove the issue with the paint falling off. Also, took the trunk to bare metal due to rust. Did use Picklex to be able to stop the rust from continuing. I did seal the metal and then used 2kprimer. This way hopefully the rust no longer shows up again. Now to begin the body Work
Name:	WhatsApp Image 2022-11-25 at 8.02.10 PM.jpg
ID:	1385241 Click image for larger version
Name:	WhatsApp Image 2022-12-10 at 9.19.26 PM.jpg
ID:	1385232 Click image for larger version
Name:	WhatsApp Image 2022-12-10 at 9.19.26 PM (1).jpg
Name:	WhatsApp Image 2022-11-26 at 6.43.09 PM.jpg
ID:	1385235 Click image for larger version
Name:	WhatsApp Image 2023-01-14 at 6.14.37 PM.jpg
ID:	1385244 Click image for larger version
Name:	WhatsApp Image 2023-01-14 at 6.14.37 PM (1).jpg
                            As I continued with painting the roof and trunk, I did continue with more rust work. The Driver floor had some rust which I did cut and patched. May not be the best but it works. Also the rocker panel is bad. Currently working on all the rust. Currently Using 3 x 1 rectangular tubing to reinforce the area. Also started the Manual Swap on it. Removed the transmission. Now, I will also remove the Motor to do some maintenance on it since it only has 120k. Want it to last a bit before upgrading.
Name:	WhatsApp Image 2022-10-29 at 5.29.51 PM.jpg
ID:	1385249 Click image for larger version
Name:	WhatsApp Image 2022-11-15 at 6.47.47 PM (1).jpg
ID:	1385250 Click image for larger version
Name:	WhatsApp Image 2022-10-29 at 5.29.51 PM (1).jpg
Name:	WhatsApp Image 2023-01-17 at 6.19.58 PM (1).jpg
                              Looks good.
                                Jesus, all this rust in FLA? My dad has a place damn near right on the water but I never see cars with any rust on them when I visit. Certainly nothing like we see here in MI.
