Looking good dude, especially with all the frustration you dealt with.
Larisa "1982 Lincoln Continental Mark VI Bill Blass 2-Door
Originally posted by His Royal Ghostliness View PostNeeds a MSD coil. Cause color coordination!
I agree eventually i will replace the cap and coil with an MSD one so colors match, wonder if msd makes a red ford starter solenoid cause mine is blue just like the coil.
Originally posted by MattsLincoln View PostI agree eventually i will replace the cap and coil with an MSD one so colors match, wonder if msd makes a red ford starter solenoid cause mine is blue just like the coil.
Just don't forget to turn the light off. That would be a good source of a dead battery for no obvious reason.86 Lincoln Town Car (Galactica).
Originally posted by 86VickyLX View PostI think they do. I'd honestly just paint it cause MSD don't do diddly dick unless we're talking about high rev applications.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
perhaps, though I find mine runs better with boring copper plugs.86 Lincoln Town Car (Galactica).
Nice Matt. I like the underhood light.~David~
I wouldn't mind having one of those lights. I'd be able to mount it in a similar to stock spot.
Can't put it in the center, since that's where the engine hits the hood....__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
Originally posted by Bobcat View PostI wouldn't mind having one of those lights. I'd be able to mount it in a similar to stock spot.
ok so i will start gathering them junkyard run in 2 weeks there $10 each, i have 3 people that want one so far correct ? Logan, Gabe, and David ? John Sexton acquired one earlier this week for him.
I got the ford version. This David don't need one. Thanks though Matt.~David~
ok so just logan and gabe.
If you come across another, I would be glad to have one.
Thanks,
jay03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
UPDATE: Finally did my mod and was able to use red lighting gel to change the color of my digital readout, works good but fuel gauge and message center display are hard to read due to the displays not being as bright as the speedometer reading, this will be all fixed once i find an 89 town car digital cluster as they have updated stuff on the circuit board and its display is much brighter than early digital dash displays.
