Evap drain clogged seepingninto car? Firewall grommet leak? Gasket for air intake leak like the Lincolns of the era have/do from 98-11?
1997 Mercury Grand Marquis LS
Originally posted by TecNickal View PostEvap drain clogged seepingninto car? Firewall grommet leak? Gasket for air intake leak like the Lincolns of the era have/do from 98-11?
My Cars:
Originally posted by TecNickal View PostDriver rear? Hood release grommet, coal leak in Seam sealer? Factory wiring harness grommet ?
I took my carpet shampooer to the interior with the handheld component and cleaned the carpets really well. The floor mat that was wet had a orange-brown color coming out of it. I suspect rain water as we've had strong storms lately, but I've never encountered this in the car before. I'm sure I'll find the source once I get things taken apart.
My Cars:
Originally posted by DerekTheGreat View PostMight water be getting in via the coach lamp??
My Cars:
Just another reason I never bring my car to anyone. Nobody cares as much as you do.~David~
Somebody lost one of those 50 gallon plastic trash cans today. I managed to find it on the freeway at 65 MPH and I couldn't swerve around it, so I bounced it off the right corner of the bumper.
Post-strike:
It was mostly plastic transfer from the can to the bumper. It smacked it straight on the turn signal light housing and cracked the paint a bit underneath it. The impact broke a locking tab on the turn signal socket which knocked it free from the bulb. The bulb got the filaments broken so I tossed in a clear bulb just to have a functional signal.
Post-cleaning:
I busted out the cleaning stuff when I got home. I used Scratch-X to get off the transfer, NuFinish to polish the area, and Turtle Wax paste wax to seal everything up.
I got a new socket and bulb at work and installed those. Despite the bumper cover being slightly more out of alignment than before (was never quite right to start with), everything cleaned up reasonably well.
My Cars:
I bounced a construction barrel off the front of the aero once. Launched one off the front of the Mad Marquis once. Both had just little scratches and no other damage. I was impressed. Of course, both of my impacts were much slower... ~45 and a glancing blow off the right corner for the Cake and about 30mph almost dead on the right corner and kicked it clean off the road on the Marquis.
Originally posted by sly View PostI bounced a construction barrel off the front of the aero once. Launched one off the front of the Mad Marquis once. Both had just little scratches and no other damage. I was impressed. Of course, both of my impacts were much slower... ~45 and a glancing blow off the right corner for the Cake and about 30mph almost dead on the right corner and kicked it clean off the road on the Marquis.
That silly trash can spun around to the shoulder and uprighted itself after I hit it. Road debris sucks.
My Cars:
I had a woman in a BMW talking on her phone coming up on a construction zone not paying attention try and run me off the road in the Town Car. There was a lane shift and she just kept going straight. End result was discovering that those orange barrels and my drivers side mirror are the exact same height. Nailed that thing at 65mph with the mirror. So close to missing it entirely. It swung the mirror into the door so hard that it flung the glass off the mirror into the window with enough force to chip the window. Talk about a godawful noise. Amazingly it did zero damage to the mirror housing, but the mirror glass was beyond repair and the tabs that hold it to the motor were gone. Pulled a junkyard mirror off a '95 Townie and took the glass and motor out of it, then gave the housing to my buddy because his Townie had a broken housing and this one was silver and almost matched his silver/green car.-Steve
The '97 just completed a road trip around 1,700 miles from GA to IL and back again. Rolled past 191K, closing in on 192K. Did rather well considering it hasn't taken any long trips this year and has been handling daily stuff. Now it needs a wash down really bad from how many bugs wound up on the front.
Snapped some pictures in TN on the return trip. There was a rest point somewhere on the south tail of TN State Route 111 just north of Chattanooga.
Ugly duckling:
The angle I took the picture from really makes the bumper gap look really bad. That's a combination of the fact it's never been right since 1997 (warranty receipts show the original owner tried to have it adjusted), the fender install fudged the lines a bit, and then smacking the trash can at speed. It'll all get straightened up as good as possible whenever I send it away for paint. I'd like to do that Thanksgiving week, assuming things work out time wise.
Really need to find some LTC seats or re-stuff these. 13 hours in these seats kind of wears on you. I guess nearly 200K will do that. Just need to find a good set of Light Graphite seats. So many that I find that match are just shredded or cracked.
My Cars:
Sounds like how my '69 Fury made me feel after that one road trip I took, only that thing totaled me. I never drove it long distance again and lost interest fast because of it. Short of fabricating something there was no easy way to make that thing comfy. Solution was to sell and replace. Not so sure on the replacement part, I like not having to manage repairs on multiple cars. We're down to four right now.1985 LTD Crown Victoria - SOLD
Love the scenic overlooks.~David~
