Originally posted by sly
View Post
1988 Lincoln Town Car
Nice work cleaning everything up.~David~
What is the red thing in the heater hose? If you're shutting off flow to the core, it will screw with what the ECT sees since there isn't good coolant flow past it anymore. That will affect what the ECM does for fuel and such.86 Lincoln Town Car (Galactica).
Originally posted by DerekTheGreat View PostCame here to say exactly this. I want one. Gold looks nice too. Oh and holy hell that engine was nasty before! Leaking from everywhere possible and looked like it had been run hot multiple times.
Actually, it didn't leak as badly as some or as badly as it should have. Averaged a quart for every 1000 miles. Main seals and base pan gasket was tight. Most of the leaks were top end (intake manifold and valve cover gaskets). That was combo leaking and burning (all 8 valve stem seals were risen to the tops).
As for run hot, it only did once. But it was a bad one. It was the beginning of the end of that engine.Last edited by nfldfordltd; 05-03-2017, 08:49 PM.Summer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
Originally posted by 87gtVIC View PostNice work cleaning everything up.
I guess I'll have to take some pictures of it installed to show what it really looks likeSummer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
Originally posted by gadget73 View PostWhat is the red thing in the heater hose? If you're shutting off flow to the core, it will screw with what the ECT sees since there isn't good coolant flow past it anymore. That will affect what the ECM does for fuel and such.
I did have to make a restriction for the heater core inlet tube because I was sick and tired of replacing heater cores. It still flows well and there's no codes for the ECT, plus I can now get longer than a summer from a heater core.Summer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
ok, no problem. As long as its moving coolant its good. Looked a bit like a valve of some sort though.86 Lincoln Town Car (Galactica).
Originally posted by nfldfordltd View PostIt's a garden hose coolant flush fitting, installed where the TBL switch used to be.
I did have to make a restriction for the heater core inlet tube because I was sick and tired of replacing heater cores. It still flows well and there's no codes for the ECT, plus I can now get longer than a summer from a heater core.1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostI thought these things already had some sort of restriction in place, just inside the feed tube for the heater core? There's some sort of black restrictor thingy in mine. Could've been put there by someone before me though.
I made mine by cutting a hole in one of the rubber end caps that came on the replacement core, putting it back on over the feed tube, then sliding the heater hose on over the end cap/feed tube and putting the clamp back on. Second year on this core now with no issues, hopefully it hangs in there. I've lost count of how many heater cores I've replaced in this car. I do remember having one that lasted less than a fortnight.Summer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
For the hell of it, post number 800! hahaSummer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
Originally posted by DerekTheGreat View PostLoL, I have never posted so much to a forum in my life. Something about this one.
Guess I meant to say feed HOSE. That's the job that's got a restrictor in it with my car. Might have been put there by someone else.
My car has all new heater hose, some of which is molded OEM-style hose. Original and new stuff has no restrictors of any kind, I'm guessing yours was put there by a PO. My theory on it is the original TBL switch was choked off a bit, creating a natural restriction from the factory. If it was in the correct line, I can't recall now if the TBL was in the feed or return line.Summer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
Yah, the peeps are good on here.
My stuff must be all original, which is a bit of a yikes factor but until they start to piss or look rotted/swollen, they're going to stay put. I think the TBL is on the feed line, would make sense as that's hottest and would activate that heat element thing inside it faster.1985 LTD Crown Victoria - SOLD
hehe... nah... you don't post much
Originally posted by sly View Posthehe... nah... you don't post much
But I am senior in years thoughSummer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
