Does look shiny indeed. Glad she's running around while you row the boat!
1983 Mercury Grand Marquis 2Dr "Mercules”
Originally posted by 87gtVIC View PostShe shines up good.
Did the lower mustang seal cover up your hole?1983 Grand Marquis 2Dr Sedan "Mercules"
Originally posted by Grand Marquis GT View PostTurbines
Thanks to MrMarquis for hooking me up with the caps!
Jesus.__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
They look perfect.~David~
They are far from perfect, but they cleaned up good.
I also got the clutch adjusted just right. So fun to drive! I also figured out the little quirks with the TKO and its notchiness. I will consider this swap a complete success! Later one I need to go get some more self-tapping screws so I can install my lower boot and the plate I fabricated to cover the big gaping hole in my floor. It will quiet it down quite a bit.1983 Grand Marquis 2Dr Sedan "Mercules"
The wheels are perfect for the car. I love turbines. So sad I cannot run them.~David~
Hi GMGT
Just going to rub one out
Regards
DereckPresident and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
Tom in all seriousness can the CFI lopo lite 'em up with the new set up?~David~
I'm running the closest thing to stock turbines I can, Mark VII LSC turbines. If they made the lacey Lincoln turbines in a 16", I'd have those on my car in a minute.86 Lincoln Town Car (Galactica).
Originally posted by 87gtVIC View PostTom in all seriousness can the CFI lopo lite 'em up with the new set up?1983 Grand Marquis 2Dr Sedan "Mercules"
Nice! Turbines look great too! Best Panther wheels ever (HPPs, are a very close second)2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Thanks mang.
The merk is quiet inside once again! Built a cover plate out of some steel, seam sealed it and screwed it down. Also installed the mustang lower boot (as a gasket/lower boot) and the Lokar upper boot I got from Brent (visionmercury). It's a redneck/temp job, but works well enough that the inside of the car is quiet when hooning around with an open H pipe!1983 Grand Marquis 2Dr Sedan "Mercules"
Looks fine. Throw some carpet over that and all sins will be hidden.~David~
