Did a tuneup today:
Plugs
Wires
Air/fuel filter (screw on type fuel filter, really weird)
Cap/rotor
MSD Blaster 2 coil I had laying around
Still idles like shit. Runs great though, moved around the block a couple times pretty well. Getting some semblance of an exhaust next week, when the parts come in!
1983 Grand Marquis 2Dr Sedan "Mercules" Tremec TKO conversion, hydraulic clutch, HURST equipped!
Adjusted the clutch a little, and included some photos of what my slave cylinder setup looks like. Added a locking nut and return spring/bracket that I made from some stuff I had laying around. Went for a cruise, 75 mph cruises good! 80 mph does pretty god too up on I-20!Also, it's got a cam...just not a performance piece! Good ol' EEC-III shit idle!
Do the CFI EEC III cars really idle that bad? Back when I owned my 85, that thing would idle smooth as butter. It had no balls but damn it idled so nice, way better then any SEFI car I've owned.
It shouldn't run that bad. Idle quality wise, the other two running EEC-III cars I've heard ran as well as any other CFI car.
It shouldn't, but does. I suspect a bad TPS. Ah well.
