The headers came out like they were installed yesterday. Got the new ones in & started on the X-Cat Pype. After much screwing around I compared them to the set in the 87 CS. No ceegar. one of the pipes is incorrect. They are shipping me a new one.
Mean Mr. Mustard
New pipe was received in 2 days.
Been driving it. Still has fuel issue. I think the regulator and/or injectors are hosed.
Ordered a new fuel level sender.
It arrived in pieces. They sent a new one a few days later.
Ordered a new fuel tank for the blue car, arrived damaged.
Anyone noticing a trend here?
I believe I've got a good set of 19# around here if you need them. They came from my car when I upgraded to 24#. 95% certain I have them and know where they are. Which of course means I'll never find them.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostI believe I've got a good set of 19# around here if you need them. They came from my car when I upgraded to 24#. 95% certain I have them and know where they are. Which of course means I'll never find them.
Have the tank out for new fuel level sender & inspection. The black plastic tank protector is dull & dirty. I have some "black trim restorer" I am debating that vs some black "plastic" paint.
Also, installed Ford racing plug wires.
The restorer works but only for a while. The paint will probably hold up better color-wise provided it sticks.86 Lincoln Town Car (Galactica).
Originally posted by mitymerc View PostIt's been many years since I have been immersed in the Fox thing.
I do not recall the black fitting on the return line by the tank. The hose is reluctant to slide on. I wonder if the fitting is necessary or a remnant from the manufacturing process, any one know?
[ATTACH=CONFIG]52553[/ATTACH]
[ATTACH=CONFIG]52554[/ATTACH]
what he said. The metal line should be just a metal line. Thatsa common fitting, should be able to find replacements for it at the parts store. If its the vapor or return line you can cheat and just use rubber hose to connect it.86 Lincoln Town Car (Galactica).
Installed "new" tank , line & fuel level sender
Some shit bag in a Uhaul hit it & kept going on Sat night. Neighbor got a photo of plate. Police don't think I will be able to get anything from drivers ins co, but maybe through Uhaul's.
A holes.~David~
