ClayBelt’s 2010 Mercury Grand Marquis, “The Douche”
    Have you become the neighborhood alarm clock?
      Nope, just the alarm for North Residence Hall telling them when breakfast closes on Saturday
      It’s a sweet, sweet demonic roar though, even if it did slow the car a wee bit.
      2010 Mercury Grand Marquis LS “The Douche” - 70mm throttle body, P71 airbox, 21mm rear sway bay, dual exhaust, Dodge rims, 89K and counting. 4/2018-
      1966 Ford Thunderbird (390FE) “Fordy McFordface” - engine rebuild No. 3. 11/2016-
      RIP 2005 Buick LaCrosse CXS “Jumba” - gone too soon, 229K. 6/2017-2/2018
      RIP 2001 Chevrolet Tracker LT “Featherbrick” - gone too late, 156K POS. 6/2016-9/2016.
      Sold 2005 Toyota 4Runner SR5 - 198K. 6/2016-4/2018
        Detailed the engine bay this afternoon. Have a car show I am going to Saturday, figured it was finally time. Turned out rather well.
          Replaced the stock door speakers yesterday, same ones I used for the rear deck. There is a slight sound difference, just enough to tell it isn’t stock if you’ve heard a stock panther sound system.
            What cut outs did you go with? I have been wanting to do the same.
            10/2018
            2006 Mercury Grand Marquis
            Ole Blue Hair
              They’re the cheapo’s off Summit Racing. Either permanently open or permanently closed
                Bought a Lincoln LS throttle body I am going to try and adapt to the Merc. Near as I can tell, it’s a 70mm unit I pulled off a 3.9L V8 engine. Big concern I can think of will be intake tube, as I am pretty sure I can machine it the way I want.
                  Here's a CVN link that might be worth consulting [edit: I subsequently noticed that you had recently made a post in it]:
                  Ever since I signed up with CVN I've been looking for the optimum intake upgrade. There even was a time when I almost bought a CAI. After reading the MZT thread in the BoK I decided that a CAI just isn't necessary. The other problem that I faced was that I want more than just the MZT. The…
                    Gave in to a whim and spent $20 at walmart for the tools I need for the throttle body. I may modify more of them for other Panther owners if the results are satisfactory, so I consider the costs well spent. Going on this weekend.
                      Installed the throttle body today. Had to get an adaptor for the P71 zip tube, opening was too large. Recommend going to a CAI style pipe to the air box if someone did that upgrade.
                        I know for my 2000 MGM, a 2004 CVPI zip tube is both too short and too big at the air box end. Apparently some people cut off the air box end of the original zip tube and clamp the CVPI zip tube over it, though that's not something I'd bother doing. What did you use for an adapter?
                          Got a 4” to 3” intake coupler. Had a 4” to 3.5” ring I used on the 4” end
                            pics or STFU
                                I’ll get them in the morning, had to replace the shocks I blew while testing throttle body on car. Too dark now
