Originally posted by clutch47
View Post
'Sherrie' my 86 Oxford White CV Coupe
—John
1985 Ford F-150 XLT Lariat
I have used the visegrip method as well. I believe all 8.8 rears were originally 28 spline through 03. not sure if they changed in 04 or 05. possible exceptions being limos rears and trucks?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
pretty much. I think 05 was the switchover... mid year. Exceptions being the Marauder IIRC.
03 Marauder was 28. I believe the 04 was also. Though strangely enough they used a unique carrier.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
ah... I guess I didn't remember correctly.
With all the details of modern engineering it is amazing we remember significant parts of anything.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Especially since I've never been inside any axle except the one on my 93... with Scott's help. I'm just remembering all the stuff posted here.
Originally posted by Mainemantom View PostI found your stainless trim for you. Part number EOAZ54291B20A
See Ebay listing #162202677470~David~
Looking for some help from ya'll...
I know there's a nice clear vacuum diagram on here somewhere that is appropriate for my car. I've been looking for a while to no avail.
My goal is to re-evaluate all my remaining vacuum lines and try to downsize or simplify if I can and get a cleaner and the most powerful signal I can to my brake system. After this 347 swap and knowing my cam specs....I should still have nice power assisted brakes.
What I have is the 86 brakes that truly aren't too 'power' anymore.
I'm also looking for the strongest signal I can provide the HVAC system and where on the firewall it actually draws it's signal through.
Cam specs/card
All FORD All The Time
Have you checked the fan shroud? There should be a sticker on it with all the info you need on the vacuum lines. I remember when I first got my '85, I was searching everywhere to no avail for a correct vacuum diagram. Then while I was standing with the hood opened I noticed it.1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostHave you checked the fan shroud? There should be a sticker on it with all the info you need on the vacuum lines. I remember when I first got my '85, I was searching everywhere to no avail for a correct vacuum diagram. Then while I was standing with the hood opened I noticed it.
I'll look today EHRMAHGERD...All FORD All The Time
