My '85 MGM, "Maisa"
Originally posted by Mainemantom View Post[ATTACH=CONFIG]57180[/ATTACH][ATTACH=CONFIG]57181[/ATTACH]
I have this. It is brand new. You may have to trim the underside to properly fit the hump. If interested, pm me.
Conclusion: too big for my taste.
Originally posted by bnw View PostDo you maybe have one in another colour, or one that is in a worse state, so it needs repainting? Might use such a console for one of mine panthers...
Had some discussion on a finnish forum about thermostats, waterpumps, heater cores and more specifically about heater core restrictors.
I have seen those mentioned here and there on this forum aswell. That raised the question in my mind:
Should I get a heater core restrictor for mine? I'll be changing intake and heater hoses among other things in the spring.
I'll be eliminating the broken and disabled heater core valve and the EGR cooler related T-piece and lines aswell.
Of course it won't hurt anything, but is it really worthwhile, my heater core is original and the RPM range of my engine won't be changing at all.1985 Mercury Grand Marquis LS, "Maisa"
My heater core failed several years ago, found out I already had a factory restrictor in place and yet it still failed. I think when it comes time to changing coolant in my cars they'll all get Evan's. Stuff doesn't expand and so maybe that'll help me get more life out of pressure sensitive items like that.1985 LTD Crown Victoria - SOLD
What thats really for is to reduce flow in the core at high RPM so its less likely to blow up. Won't prevent it from going bad from age or normal driving but if you spend a lot of time at 5000 rpm its a good idea.
I remember the first drive in Natehawk's 351 swapped 85 Vic. The first WOT pull the core exploded just before the 1-2 shift. It was a fairly new heater core too. It got replaced and a restrictor went in.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostWhat thats really for is to reduce flow in the core at high RPM so its less likely to blow up. Won't prevent it from going bad from age or normal driving but if you spend a lot of time at 5000 rpm its a good idea.
I remember the first drive in Natehawk's 351 swapped 85 Vic. The first WOT pull the core exploded just before the 1-2 shift. It was a fairly new heater core too. It got replaced and a restrictor went in.1985 Mercury Grand Marquis LS, "Maisa"
stock trans shifts about 4500 but you can manually hold first gear if you want to. No reason to, it doesn't make any power up that high.
basically its one of those things that isn't a bad idea, but I wouldn't stress too much about having one. The one in my car is just a washer that I stuck to the inlet of the heater core with a dot of RTV before putting the hose on.86 Lincoln Town Car (Galactica).
I'm still going through my list of everything to do for the carb swap... Does the CFI choke heater power wire work the same as with a normal carb electric choke? Or is it timed by the ECM somehow?
Also thinking about giving the engine bay a little bit of spruce up.
How about gold valve covers and air cleaner like in the early 60's? Not really feeling the ol' Ferd Blue...
You need to know what voltage the choke heater expects. The stock system runs around 8 volts or so using the S (stator) terminal on the alternator. If the carb's choke heater wants 12v, that will cause it to either not open or take a very long time to open.86 Lincoln Town Car (Galactica).
