The E7 heads on my car were switched over to the positive seal types before I got them. If you look up parts for 5.0 Explorers you get ones that will pop onto old heads that aren't the umbrella type. Found that out when the seals self-destructed after the cam swap. Did the air method to change them, worked out OK other than physical discomfort from spending too much time leaning over the fenders.
My 1968 Mustang Rustang
Originally posted by Tiggie View PostI did use the rope this time. Had no choice really since they wouldn’t hold air before. It was a little more tedious because the valve fell a little bit, but very doable. Those black plastic shields/seal got in the way of a couple of times and prevented me from lowering the valve spring enough. Not a huge deal but required repositioning of the rope. I’d consider using a set of the intake seals on the exhaust to get a positive seal on all of the valves. Might help with the lopo oil consumption. I bet they can take the heat fine...
Originally posted by gadget73 View PostThe E7 heads on my car were switched over to the positive seal types before I got them. If you look up parts for 5.0 Explorers you get ones that will pop onto old heads that aren't the umbrella type. Found that out when the seals self-destructed after the cam swap. Did the air method to change them, worked out OK other than physical discomfort from spending too much time leaning over the fenders.1990 Country Squire - weekend cruiser, next project
Thats my best guess. It was fine before the swap and within a week afterward it was burning lots of oil. 14 of the 16 seals had the middle rubber bit shredded. New seals and its been fine ever since. The old seals were soft, just ripped.86 Lincoln Town Car (Galactica).
Garage therapy tonight. Much needed.
Timing cover went on. It’s a repop. Had to drill out for the dowels at the bottom. Also, spent stupid money on bolt kits. Two of the six bolts were still not the right length. Luckily I had two in my bolt drawer. They aren’t flanged but a washer fixed that.
The Summit-brand balancer went on next. They were one source for the early 3-bolt pulley setup with a 50oz (im?)balance. Looks nice.
Water pump followed. I wanted a reman to look the part for originality. But apparently they don’t reman water pumps any more, at least not at common parts sources. Not having a proper OEM core to send in to be rebuilt, I just went with whatever they listed as a higher flow model. It does have an 8 blade impeller. I’m not crazy about it’s appearance. I think I’ll restrict the heater core. *reminder for later*. I don’t want it getting hot in stop and go traffic. It came with a big block size radiator and upgraded fan since it’s an A/C car, so hopefully that will help too.
And finally, a timing pointer. No pic. Never had one of those before on this car.
I stabbed the distributor in there to make the oil pump driveshaft happy when this goes upside down for oil pan install. Distributor is points because they work and warn me when they don’t want to work any more. I did swap a steel gear in place of the cast iron. I haven’t drilled it yet for a dowel pin. Do you think it needs one? It’s a press fit.
Also I found some 3/8 expansion plugs at RockAuto. Stopped up the dipstick hole in the block since that won’t be used here.
This will all turn blue at some point.
Rockers and pushrods will go back in next session.
Sent from my iPhone using Tapatalk1990 Country Squire - weekend cruiser, next project
Garage is a huge mess. But a scrambled all weekend and got this sealed up and painted. Looking more like 1968.
Bypass hose got painted. Strange but seems they came that way. The lopo one was engine gray also, so it was a multi decade thing I guess.
I like it. In my mind I like to think painting everything assembled this way will stop unwanted leaks. Doubt its true but it cant hurt.~David~
The factory paint jobs weren't that wonderful. I ran into a guy with a clean low miles 93 Cobra. Original owner car, like 15k on it. The black valve covers had grey overspray from when the block was painted.86 Lincoln Town Car (Galactica).
Originally posted by 87gtVIC View PostI like it. In my mind I like to think painting everything assembled this way will stop unwanted leaks. Doubt its true but it cant hurt.
Originally posted by gadget73 View PostThe factory paint jobs weren't that wonderful. I ran into a guy with a clean low miles 93 Cobra. Original owner car, like 15k on it. The black valve covers had grey overspray from when the block was painted.1990 Country Squire - weekend cruiser, next project
The goal was to have the engine in by last weekend.
To make a long story short, I lost my mom a week ago today due to a brain bleed. She was 65. So this has been on the back burner along with everything else.
Dad is my chosen teacher/helper on this because he knows how OCD I am. I get it from him and mom. Dad now needs something to take his mind off mom, so I’m trying to throw this into high gear and get the motor and trans in the next two weeks and he can help.
I cleaned up the exhaust manifolds Saturday. One is original to the car, the other is off a rusty 65 Galaxie (the one pictured, it’ll be covered by a heat shield). It wire brushed them to get the lose scale off, and then used spray graphite to make the look nice and hopefully not burn off. Got the idea on YouTube.
New plugs installed.
I hate the look of exhaust manifold gaskets, so I cut these to hide the unsightly part. I don’t know if that was smart to stupid, but time will tell. Looks better anyway.
I have a few small parts ready to paint, might do that tomorrow.
The mystery trans is ready to go in except it looks bad. It’s clean but doesn’t look new like the rest of the car. So it might be time to whip out the alumiblast paint. That would be the next thing, then the trans can go in.
Sorry to hear Ben. Good idea on keeping dad busy. Good luck.~David~
Oh man...sorry for your loss. It's great you and your dad have a project like this to work on together. Engine and manifold look great-Phil
Condolences on your mother, man. Tough times.—John
1985 Ford F-150 XLT Lariat
Thanks guys.
Put the dipstick tube in last night. I had purchased a reproduction dipstick tube, long story short, they make tubes, they make dipsticks, none of them are the right length to match each other. I was able to get the tube out of the donor engine, which I had previously salvaged from a 1969 Fairlane. Small steps.1990 Country Squire - weekend cruiser, next project
