yeah its the same bushings as all the rest of the boxes.
Push the little tabs in at the corners of the glove box and flip it all the way out. Should be able to see whats going on in there at that point. I seem to remember the bulb lives right near the little button that turns it on.
My 1983 Continental Mark VI!
Originally posted by VicCrownVic View PostIf the switch for the door lights is the same as what I'm used to it should be adjustable. If the door itself looks lined up right, then adjusting the switch out one click might be all you need to do.
I still can’t find a light socket in the glove box but there sure seems to be a switch. There’s some hacked up wiring under the dash and the dip stick who put the after market radio in hack installed it without a wiring harness adapter so it has constant power!
I have to pop the faceplate off to get the lights to go out, it’s aggravating when people do dumb shit like that. They also left out half the screws for the dash trim so I had to replace those.
They also mangled the tracks for the ash tray. I don’t smoke so I’m just going to wire in a cigarette lighter/usb combo so I can at least charge my phone. There’s a spot under there it should fit nicely.
It’s all little dumb shit but I like to get things fixed and done with, and it’s 80 degrees and humid here at night so it’s all aggravating me a bit more than it should.
No luck on the brake light yet. The parking brake pedal is all the way up. I haven’t looked at the wiring to the proportioning valve. Wiring and I don’t get along so well.
Leave a comment:
Leave a comment:
Originally posted by gadget73 View Postverify the parking brake is pulled all the way up too. If thats not quite right or the switch is a bit flukey it will cut in and out. Same with damaged wiring to the prop valve.
Nice ride. The four door Mark VI is not one you see too often. Also just know that 80-83 CFI is different than 84-85. EEC-III vs EEC-IV. Most of the sensors are different and rather difficult to source now.
Leave a comment:
Leave a comment:
prop valve has a switch on it. take a look around the fender well behind drivers side tire area on the frame. It should also be tied in with the e-brake down by your left foot. there is a switch that grounds when e brake is applied.
Leave a comment:
Does anyone know what triggers the brake light in these cars? The brakes and parking brake work just fine. The door light comes on randomly too, I’ve narrowed it down to the rear drivers side door. I think the striker needs a bit of adjusting.
Leave a comment:
Originally posted by DerekTheGreat View PostIndeed!
That top looks great too, no separation anywhere.
Leave a comment:
Originally posted by Giraffe View PostIf it's the same bulb as in my '90, it should be a 194. The bulb socket should be on the right end of the switch/latch.
Leave a comment:
Originally posted by mercurygm88 View PostDoes anyone know if the Mark Vi is supposed to have a glove box light?
There’s a plunger switch in there with wiring coming out the back but I can’t find a bulb socket unless it’s that weird little T shaped slot to the left of the plunger.
If so does anyone know the bulb number?
Leave a comment:
Leave a comment:
Originally posted by slack View PostLooks fantastic and at a great price. Congrats!
Leave a comment:
Leave a comment:
