Well i needed a cheap daily driver that was good on gas after i sold the dodge back in february and ended up picking up this 96 sonoma 2wd. Its only a 2.2 L4 automatic with 124k on it. Vinyl flooring with a shitty bench seat and a rot hole under the sil plate on the drivers side i need to repair before winter. Funny thing is it goes the length and width of the sil plate and stops. I added the same model pioneer cd player i had in the dodge that i sold with it. Runs great and gets good mileage all that matters till i can get the mercury fixed.
Repairs done
New rotors, pads with bearings, races and seals
All 4 shocks replaced with Gabriel Pro Guards
Gabe wired up the fog lights for me
New idler arm
New center drag link
Replaced a tailgate cable
Installed a sunpro oil gauge with copper line
New cheapy coil packs
replaced the rusted away head light buckets
both upper ball joints since the passenger busted on me while driving home one night
replaced the gas lines
rebuilt the motor and added a stainless header
thermostat
muffler and tail pipe
pcv valve
swaybar links
all new motor internals when i rebuilt the motor except cam and cam bearings (because the motor shop told me they were fine but i still have shitty oil pressue at idle from the bearings)
I just picked up a nice set of rims from an extreme for it today.
First pic is the day i got it, i did remove the tail light covers since i didnt like them. 2nd Pic is with the new rims i just got.
Repairs done
New idler arm
thermostat
pcv valve
swaybar links
