yellow fever
yellow fever
Tags: None
you're an addict!
oh hey that reminds me, I grabbed that trim for your damaged door. If you don't have a door, I can probably go get it from the car that supplied mine. They were all in nice shape, and I'd been considering pulling them just to have.
are those correct authorized IH accessory headlights? If not, you know the tractor guys at R&T will give you slack about it.86 Lincoln Town Car (Galactica).
Are you going to paint the TC to match?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
those headlights are not factory, i like the way it looks tho.
been at it most of the day puttin chains and weights and the 10" brinly plow on the 123
i got a door but iirc no bottom trim
ok, well I got you bottom and middle trim. Remind me to bring it with me. I did forget to pull the bottom clips off of the door I just scrapped though.86 Lincoln Town Car (Galactica).
yes i know the mk7 is deflated, on my list, battery won't charge
Tractor Of The Month????
the 71 and the 72 are 7 hp kohlers, both run excellent!
the 123 has a 12 hp kohler and a hydrostatic trans (first garden tractor to ever have a hydro) engine runs good but smokes.
the 100 (the one missing a few bits) is a 10 hp kohler......it runs......i gotta tear the engine apart and send it out, block deck not true, blew the new head gasket, prob for the best, it is a april 1964 tractor lol
not pictured in recent pics are my other model 71 and my 127.........the 71 is gonna be my hot rod (was my pop pops, he gave it to me when i was 14) the 127 i'm gonna try to make some lifted off road mower with go fast ability out of it.
i also have a two belt drive mowers that i am going to convert to go fast tractors, one was my pop pops, i would have restored it too but i could not find the parts so easy like these cubs, and that toro was built in 1988 not 1968, go figure.
chime in if you enjoy tractors
the 123 is wearing a 3 point hitch and a brinly sleeve hitch and a 10" brinly plow. Also wearing chains and on the insides of the wheels, a pr of IH cub front weights, and on the outside a set of JD weights 50 lbs ea, the ih ones are 22lbs ea iirc. i also have a nice 38" mower deck for it.
the 71 has the optional fenders, and brinly spring assist, the 3 point and the weights came with the 71, but i decided to plow and disc with the 123. it also came with a nice 38" mower deck.
the 72 has no options, most cub cadets came this way, on it is a 38" deck from my other model 71.
the 100 has factory headlights and a tail light, it also had a 42" deck but it was too far gone and i used it for parts, included is a before pic of the 100, not done yet, needs engine gone over, clutch rebuilt, hood painted, decals, and i have a nice 42" deck that needs painting for it.
