Well, I have that switch that goes inside the driver/passenger seat, but my car has no plugs for it so it's not a plug and play item. I wanna use it however, think it will be cool if the car knows if there is someone behind the wheel and acts accordingly. So, question is, do you guys know of a system that needs to run only when the driver is in the seat, and be shut off when car is empty? Or alternatively, must not run with passengers in the car, and be active when car is empty? Any ideas, even off the wall ones?
any driver-in-seat controlled system?
They're normally for seatbelt warning lamps so the light comes on if someone is in the passenger seat and not buckled up, or sometimes for airbags depending on the car.86 Lincoln Town Car (Galactica).
Originally posted by gadget73They're normally for seatbelt warning lamps so the light comes on if someone is in the passenger seat and not buckled up, or sometimes for airbags depending on the car.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
If you were to control the ignition by your weight in the seat, then how would you get out of the car without it dying? You'd never be able to leave it running unless you were sitting in it. Just like a riding lawnmower.
Also, consider this: if you set it up to only respond to your exact weight, what if you readjust your position in the seat a little bit? Won't the car die?
Just a few thoughts. Maybe I'm not completely understanding your idea.
I hate lawnmowers with that seat kill crap. I usually disable that shit. I used to cut my uncle's grass, and his mower had both electric start and a manual backup. The starter was fried so I had to pull start it. Its a huge pain in the ass trying to pull start a motor while sitting in the seat. No idea why they did that, but the seat switch got bypassed real quick.86 Lincoln Town Car (Galactica).
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by gadget73I hate lawnmowers with that seat kill crap. I usually disable that shit. I used to cut my uncle's grass, and his mower had both electric start and a manual backup. The starter was fried so I had to pull start it. Its a huge pain in the ass trying to pull start a motor while sitting in the seat. No idea why they did that, but the seat switch got bypassed real quick.
What's even worse is a mower I used for awhile when I was working for a guy where if you had the mowing deck running and tried to put it in reverse, it'd kill the whole tractor. I disabled that pretty quick. :devilflip:
It only works for starting the car I have seen a car with it and with out anyone in the seat it wont start. If the wrong person is in the seat it wont start you just have to sit into the seat to start the car once the car is started it wont die like a lawn mower it just cuts out the wires to start the car not the power from the coil ......IT WONT DIE....lol
Originally posted by capridrifterIt only works for starting the car I have seen a car with it and with out anyone in the seat it wont start. If the wrong person is in the seat it wont start you just have to sit into the seat to start the car once the car is started it wont die like a lawn mower it just cuts out the wires to start the car not the power from the coil ......IT WONT DIE....lol
