Fule guage not working
    When i had my sending unit out i found that there was fule in the float, which makes sence beacuse every now and again my guage would read empty, so any way i changed the float and now i have no reading at all, wiggled the wires and still notthing, is my unit in the tank probly just junk?
    Could be, jumper the fuel sending lines and see if your guage moves. If it does then your sender is shit, if not check for power, and if you have power than your guage is shit.
      If you have an ohm meter, check to see if the resistance varies if you move the sender manually.
        i found out when i dropped my tank back down so i can put my new one in tomorow, that i had the float on backwords so it was wedged against the side of the tank,,thus holding it down to read Empty,, so hopefully tomorow everything goes as planned...
