Originally posted by marquisman
View Post
'79-'89 box dash removal
sigpic 1994 Lincoln TC executive
i guess i should have updated this along time ago but, this swap was not as hard as i thought it was gonna be. the only thing that was difficult was the headlight switch, so thats saying alot lol. everyone said to drop the steering column, i dident have to, the dash came out no sweat with the steering in place. all in all it was well worth it to get the new color of dash and right dash pieces in the car
Originally posted by marquisman View Posti guess i should have updated this along time ago but, this swap was not as hard as i thought it was gonna be. the only thing that was difficult was the headlight switch, so thats saying alot lol. everyone said to drop the steering column, i dident have to, the dash came out no sweat with the steering in place. all in all it was well worth it to get the new color of dash and right dash pieces in the car
I having trouble finding a tool that gives me torque and/or room to unscrew them so that i can unscrew the screw under the instrument cluster so that I can pull the dash out so that I can replace this heater core.
no need to remove the headlight switch cover on 89 down. Just the instrument cluster cover. The knobs for the headlight switch should come off with a set screw or spring clip via a T6 (or same size hex - dunno the size) or a small flat screwdriver to press the spring clip to release it from the rod. Once the knobs are out of the way, push the rod back in and the panel cover should come off once the screws are out.
If that doesn't work for the knobs... you'll have to read up behind the dash and find the rod release button on the headlight switch assembly. Major PITA this.
