Alright, I have a water leak, perhaps two - I get water in both passenger side footwells, but much more in the rear and it seems to be coming from under the passenger seat, but doesn't seem to be pooling under there (I guess because the footwells are lower?)
What do I need to unbolt for the carpet to be free in just that section? If I can get away with just unbolting that seat track and the trim holding the carpet down, I would be amazed. Plan would be to lift the carpet on that entire side to figure things out, but leave the carpet down on the drivers side.
I see no leaks in the floor when I'm under the car so I suspect one of the factory holes in it (for a seat belt bracket or seat tracks or something). Where would you look first?
Doesn't come in through the doors...the car can sit in the rain for days and not get water down there but drive for an hour and it's getting wet down there.
