So I used to get water on the back passengerside floor of the car for the longest time when it sat out in the street. Now that I'm parking the car in the driveway, the back is dry but now the front passenger floor panel is FILLED with water. I'm talking like a whole inch or two. Last time it rained I thought it was from built up leaves under the hood so I cleared everything out of the drain runoffs and shopvac'ed everything. Well the car stayed damp for an entire week so I'm assuming more water was still dripping in slowly since it never even got close to dry. Now today it rained again and there is a huge puddle again. Anyone have any idea where this is coming from? No signs of drips everywhere and I've checked all the door seals?
Extremely bad leak, please help
I have the exact same problem and haven't been able to find a solution. I thought puffing out the weather stripping (aka: pulling the weather stripping out, bending the channels up with vice grips, and reinstalling) worked but it did not. I tried adjusting the lock strikers to no avail.
On mine it comes down behind the seatbelt panel and leaks onto either the front or rear floorboard depending on what kind of an angle it's parked at.sigpic
what car are we dealing with? Year? bodystyle? vinyl top?
Pull all the trim out of the inside of the car, and get in it, and have a buddy flood the car with the garden hose... moving slowly around the car, until you find the leak. Mine was leaking from a small rust out in the upper rear corner of the back door jamb, under the chrome trim. I didn't even know it was there until I took it off to paint the car.... So we fixed that, too... no more leak into the back floor board... take all your chrome trim off, too... Also, have you checked the doors? They will get the weep holes filled with crud, and fill the doors up, until it "spills over" and runs into the car... I slammed my front passenger door one day, and it sounded like a boat sinking.. the drain holes had clogged up with trash... it had just spilled over into the car... (It finds an opening, like your speaker opening, and will start "spilling over" at that point) The rubber floor had a small puddle in it... I swear about 8 gallons of water came out of the doors when I opend the drain holes back up... I now check them often...Last edited by trwp72; 07-03-2011, 10:13 PM.
Okay so thanks for the responses guys, this is what I have found so far. It's coming down the firewall and under the carpet in the front. The back leak I'm sure isn't related but it's not the one giving me problems right now so I'll look into that later. The drain was clogged last time this happened but I cleaned it out and it still flooded again. I tried checking all the seals and weather stripping and even got in there to look for the leak but it's so up high under the dash I can barely tell. I guess I'll go over it again tomorrow once it stops raining and let ya'll know what I find. Thanks again everyone.
leak
Have you checked the heater blower motor seal on the firewall? I have found leaks there. I have just found two leaks on my 90 Crown. The antenna grommet at the side of the cowl and a leak at the flexible tube going from the door to side of cowl.(where the wires from the door go into the car) Good luck !
