LED lighting dash and filter caps
    Just ordered some led lights for my dash and was wondering what you good did when you swapped. I bought green leds for the dash backing light. Did you guys keep the filter on or did you leave it off?
    I tested on my spare 87 dash and it seemed without the filter it seemed to work better. I was wondering what works best in actual use?
    Thanks!
    -Erik
    I used 5 way leds in the speedometer. I had no choice but to remove the filters as they leds wouldn't fit other wise. Regardless I would not leave the filters in if you have colored leds to put in there as you say you have in your possession.
    From memory you will have to un bolt the actual speedometer from the plastic housing in order to remove some of the filters from the assembly.
      The filters are a blue color. They work out OK if you want bluish light with white LEDs, but don't do so well otherwise.
      I'm actually giving serious thought to converting mine back to stock from the blue LEDs it has now. The vague green color is easier on the eyes.
        old man you.
          I got all the filters out without removing the speedo from the housing, there's just enough room to get the little bubble cover filter things out.
            I picked up the 5 way LEDs.
            I saw the caps were blue in the spare I have. At first I thought they were just faded from green or something but I guess the yellowish light from the stock bulbs mix with the blue to give you the green look.
            The new bulbs should be here tomorrow. I'll let you guys know how it goes.
            Good to know I should be able to get the filters out without completely taking the dash apart. Thanks for the info!
              Mixed results... I snapped the speedo face of my stock speeedometer trying to get the caps out. Just be careful.
                Much better since I switched back...and yes I'm old...and grumpy!
                I'd rather be a failure at something I love than a success at something I hate.
                George Burns
                  So taking the filter should just give white/clear light? Never was back there but sounds like the filters give the green appearance. Mine are all original and seem to all be intact. Could be brighter so thinking my headlight switch might be "funky" as it is also original. Have it turned up all the way but at night still have some issues with reading the dash well. Oh, yeah...I have "old eyes" too!!
                    yeah... you gonna take the cluster apart (the film is mounted near the bulbs at top between the face plate and gauges on the box merc clusters up to 89).
                      These are what the caps look like when taken out of the dash if anyone's interested.
                        mine (MGM) doesn't have those... it has strips of blue film.
                          Hmm.. mine might not either then actually. That's one of the filters off the extra '87 CV speedo I have. I probably won't dig into my '89 speedo until tomorrow night to see what I have.
                            The strips are a newer style thing. The 89- at least have the domes.
                            Its like ZipLok bags. Yellow + blue make green.
                              Following up...
                              Yes I had the domes.
                              Yes it's very bright with new LEDs installed without the caps on. They don't even fit with the filters on.
                              And yes it's possible to remove the filters with the speedometer still installed if you're VERY careful with the filter by the shift indicator. The rest come out okay, that one you need to pry up on the face of the speedometer very carefully and hope it's not too brittle where it will crack.
                              I'm digging the results. Full write up is in my sig.
                              Here's an image for those that down the line don't feel like searching:
                              Link to post: http://www.grandmarq.net/vb/showthre...l=1#post726557
