Here's my problem. So how the nut inside the uni body from has gotten striped. I changed out all of plastic collars. 3 went fine the drivers door will not tighten up. I have chase it out even tried a brand new striker, Teflon tape etc... It wont lock down so my door wobbles...
Door striker pin
Door striker pin
91 w/ 5.0 with eibach springs for a SS Impala ,hd police shocks on front w/big brake uprade,rear shocks for F-150 HD. Dual s w/ glass packs, 15X8 A/R Wheels 5% Tint on rear.http://www.supermotors.org/vehicles/...l.php?id=11699sigpicTags: None
Cant remember if that is accessible with the interior b pillar trim off. If not, it would require a hole cut or possibly hellicoil the threads.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Thanks will look& see if I can get to it..91 w/ 5.0 with eibach springs for a SS Impala ,hd police shocks on front w/big brake uprade,rear shocks for F-150 HD. Dual s w/ glass packs, 15X8 A/R Wheels 5% Tint on rear.http://www.supermotors.org/vehicles/...l.php?id=11699sigpic
I think you can get at that from inside the B pillar. It probably will lift out through the top of the pocket. I've knocked the ones out that are on the hinge side before. Pretty sure the strikers go into the same sort of device.86 Lincoln Town Car (Galactica).
Thanks Gadget.. I wonder hown or if I can get a replacement nut in there?91 w/ 5.0 with eibach springs for a SS Impala ,hd police shocks on front w/big brake uprade,rear shocks for F-150 HD. Dual s w/ glass packs, 15X8 A/R Wheels 5% Tint on rear.http://www.supermotors.org/vehicles/...l.php?id=11699sigpic
Here's an interior pic for reference of the passenger side where the striker attaches. Drivers side will just be a mirror of it obviously....
Yes, I saved the old B-pillar chunk from when my car was wrecked.1990 MGM: $50 E7 heads, HO cam, Holley SysteMAX lower intake, HO upper intake with an Explorer TB. LSC ECM. Lincoln logs into stock dual exhaust. K&N drop in air filter. Wide ratio AOD, 2400 converter with a 3.08 one tire fire out back. Car is less slow now. Then there's the '92 Beater. Dual 2.25" exhaust with shiny tips. Rumbles nice. Super slow. Burns oil too.
Cool thanks.91 w/ 5.0 with eibach springs for a SS Impala ,hd police shocks on front w/big brake uprade,rear shocks for F-150 HD. Dual s w/ glass packs, 15X8 A/R Wheels 5% Tint on rear.http://www.supermotors.org/vehicles/...l.php?id=11699sigpic
those are slightly different than what the hinge nuts sit in on the A pillar, but at least its still something you can work with. Should be easy enough to snatch one from a donor car.86 Lincoln Town Car (Galactica).
Update: Fixed problem with a 10-1.5mm nut. There is a rubber plug underneath the b piler cover for access. Thanks for all of the info. ..91 w/ 5.0 with eibach springs for a SS Impala ,hd police shocks on front w/big brake uprade,rear shocks for F-150 HD. Dual s w/ glass packs, 15X8 A/R Wheels 5% Tint on rear.http://www.supermotors.org/vehicles/...l.php?id=11699sigpic
