1988 Marquis
    1988 Marquis
    Does anyone know what size starz or torx fitting to take out the sealt belt fastener?And what it is? Starz or Torx? Thanks. Stranded in Detroit!
    Motor City Patrick
    1988 MGM
    Torx T50 I believe. Buy several, you're very likely to break one. If you can, get under the car and lube them from the bottom first. If they won't let go, apply heat from the bottom, being very careful not to over-heat it to the point where it starts burning the carpet.
      Have to do all that? Lol. Thought i could just unscrew it from inside the car
      Motor City Patrick
      1988 MGM
        If the car was outside all of its life in the rust belt, Yes. The threads are exposed underneath the car through the body and as of a result they get pretty rusted in place.
          What he said. If you get lucky, they unscrew. In reality, they may not. If your car has been a heavy leaker for many years they might come out clean.
            Came out clean and easy. Thanks
            Motor City Patrick
            1988 MGM
              Great news. Ive broken torx bits on them before.
                Ouch!
                Motor City Patrick
                1988 MGM
                  Is it possible to clean idle/ air control valve, without taking valve off?
                  Motor City Patrick
                  1988 MGM
                    You can try to clean the port and possibly part of the IAC from inside the throttle body but it would not be the most effective way of doing it. It is only two bolts and an electrical connector so why not pull it?? If it is that bad, I'd put a new one in (OEM if possible) since you already have it removed. Some folks have claimed success by cleaning and some have not. Kinda like putting your old underwear back on after a shower!
                      Clean it while it's running. The engine vacuum will suck the cleaner through the ports of the iac and the throttle body itself. Be sure to open the throttle a bit to keep the engine from stalling.
                        Thanks everyone!
                        Motor City Patrick
                        1988 MGM
                          This. crack the throttle as needed... typically a blip will sort it when using short shots from the carb/tb cleaner. Also beforehand, with the car not running, take a rag/shop towel and open the throttle and with the rag hosed with cleaner, wipe out the TB some on either side of the throttle valve (flapper). this will help too.
