Tommorow morning, I am going to be redoing the trunk on the car. Since I had to pull everything out to work on tracing down the problem with the trunk wiring, I decided to go ahead and redo the trunk... I have always hated the way that the side panels bow and end up halfway into the side "wells" on the side of the trunk floor. So here is a list of what is going to happen...
1. ospho'ed the trunk floor where I have a little surface rust.. sand, clean and prime the floor, mostly in the "well" part.
2. Going to paint the floor, the sides of the trunk, and across the back of the trunk with truck bed spray. Most of it will be covered with carpet anyway.
3. Going to fabricate out of plywood some "wing" pieces that will cover the side of the trunk where the small wells are.
To keep them from rotting out, and to keep them rigid, they will be covered with bed liner paint as well.
They will be screwed to the trunk floor on either side of the trunk well.
Then I will glue and screw down the original side pieces to the plywood, with small screws and fender washers. This should take the "bow" out of
them and flatten them back out.
Eventually, I will mount a 10 lb. Fire Extinguisher on one side of the trunk where the plywood wings are. A tie down will be on the other side
to hold down my trauma bag.
Put the carpet back in the trunk after cleaning it, then drop the trunk organizer back into the trunk well. (The police package style organizer)
4. Photos will be taken on the progress, I will post them when I am done... I am hoping it looks as good as my design seems to look.
5. I will not be painting the inside of the trunk lid with the bed liner paint, in fact any place that the white shows, it will not be painted.
6. all of the trunk wiring will be re-wrapped with electrical tape just like from the factory, and reattached to the wire holders. I am also thinking of
"Split looming" all of the trunk wiring... Ford did the trunk half and half, and it looks weird... the lower part of the harness was wrapped, while
the part going up to the trunk lid was split loomed.... Guess "out of sight" they didn't bother "wasting" split loom....
