Can all this be done with the Intake on? I have never had to do it so I am curious.
Why does my heat/blower motor not blow hard sometimes?
pretty difficult to get at the ends of the coolant hose with the upper in place. One is in the back corner of the lower intake, the other is in the pipe between the passenger side valve cover and the bottom of the upper. Its not totally impossible to get in there, but its enough of a pain that its a lot easier to just remove the upper intake for access.86 Lincoln Town Car (Galactica).
I did it without removing the upper. If you're patient and don't have huge hands, it can be done. My double jointed shoulders probably came in handy at some point, but I don't think that's a requirement. The biggest PITA is just getting the clamps back far enough on the hose to be able to start twisting it to break the seal (if it'll come off without cutting it off). Getting them back on is cake in comparison. Though I do think I did the lower intake port by feel.
I'm looking at this thread again to try to remember why I was having blower motor issues, and if I recall the last time it happened, it was due to low vacuum from a loose dipstick tube. I think it's occuring again, and I didn't even realize it. This is a never ending cycle. BTW, I don't have egr coolant lines.87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
Mods to come: Big Brake/Poly Front Swap, PI Front Swaybar, Addco 650 Rear Swaybar, Boxed Upper Rear Control Arms, 351/Alum Heads, FRPP Valve Covers,
