1986 MGM Tudor 5.0......Prestone change time................
    So it's five years since I changed the anti-freeze and added No-Rosion.
    Is there a way to drain the block after I drain the radiator?
    Too late now but..............could I have removed the block drain plugs and put in drain petcocks like I did on my Studebaker?
    Thanks in advance for your suggestions!
    there are block drains, hex key pipe plugs along the side near the motor mounts, one on each side. Not sure if there is access to pull them but if there is, you should be able to fit draincocks in there.
