Parting out my 4dr 89 MGM LS
This topic is closed.
    As much as I hate to do it the life of this car has come to an end.Best car I've ever owned had it almost 22 yrs has 354k miles on it now... bought it from the original owner in 98 with 118k on it.Right now it is complete but everything is up for grabs except the HO engine lmk what you need.Prefer to keep it mobile until I'm ready to take the remains to the press.
    What color is the interior? I have an 88 CS and am looking for a passenger side rear door panel. I assume the sedan and wagon door panels are the same.
    88 Country Squire
    86 Colony Park, non-op'd
    89 Mark VII LSC, non-op'd
      Interior is burgandy
        Car is maroon w/ maroon/burgandy interior. All body panels are straight & rust free, clear has peeled of most.Interior is clean & rip free.Dash pad & steering wheel are junk. Big & heavy pieces will be local pick up only.
          Do you have the plastic covers for the arm rest lights?
            Yes how many you need
              Do you have the smog pump and the small while vacuum tube that goes to the tab and tad solenoids?
                Yes smog pump is still there & functioning but you do realize those small plastic lines are old & brittle will probably break when I disturb them.
                  If you could pull it all together with the little vacuum lines I’d take it all. Otherwise its fine.
                    Don't know what you mean "otherwise it's fine" you don't want it if I can't keep the vacuum lines intact?
                      I mean if you can get it without it breaking great if it does break no sweat.
                        Pouring rain here for the next few days will be late Sunday or Monday before I can take them off.
                          No biggie. Hows the interior rear view mirror?
                            Not great has some kind of stain/flaw in the mirror glass pretty common problem on these cars see it often.
                              Eh so is mine. Thanks anyway. Ill still take the smog pump and all that though.
