Adjust those rear brakes!!!
    i just adjusted mine on my camaro, and once i got the drum off i could see a punch out for that adjust slot. punched them out, greased it up, and tightened them till i could hardly get the drum back on. after i go for a test ride im going to adjust them a bit more
      If its close, you can put the car in reverse and pump the pedal a few times. That should adjust them if the self-adjuster system is working. It won't get them quite as tight, but having excessive drag will only wear the pads out to the point where they stop contacting the drum,
        stupid question here...if they are drum brakes why are you guys calling them pads....arent they called brake shoes on drum brakes???
        Addicted to 86-87 Panthers
          gadget im sure had a slip of the typing fingers... I do that too sometimes.
          Turbo was referring to the raised areas of the backing plate that the shoes rest on as 'pads'. There are the areas you see with black grease on them in the picture.
            yeah, shoes is the correct term for the friction materials in a brake drum assembly. I knew what I meant I swear!!
              I used to rivet pads to the brake shoes or was it linings when I owned an auto machine shop. Call them anything if they dont work it might not matter anymore to someone. I would rather it stop than start.
