Project Harvester of Sorrow. Update 2/20/09, Rebirth??
    HOLY CRAP!!!
    The D1VE-6015-A2B block is a very fine block. I know people who have subjected those blocks to over 1000HP with nothing more than a splayed 4-bolt main cap conversion. (Hell, I know people running them in 2-bolt configurations fully blown.) All 2-bolt production 429/460 blocks are pretty much the same as far as structural integrity and horsepower handling capabilities.
    Found this on a boating website (what a bad waste of a good engine!)
    Now the question is...is this just internet
    Or can this really be? (1000HP on a 2-bolt main!!!)
    2008 Mercury Grand Marquis GS Bone Stock
    The modern definition of "racist" is "someone who is arguing with a Liberal".--updated Peter Brimelow quote.
      Originally posted by blazingmarauder
      Bottles are for babies. Real men get BLOWN!
      Then call me a baby and let the real men get blown in the pocketbook
      '80 Town Coupé
        Take it to the battlefield...
          Actually if a motor can hold up to being blown in a boat and not explode, its damn strong. Marine use is probably some of the more extreme conditions you can subject a motor to. Constant load and always spun up over 3000 rpm even for an easy cruise. Our 30 foot weekend cruiser clocks along with the stock smallblock motors spun up to 3600 rpm for hours on end.
            Block is going in to the shop at the end of July. I am reusing the stock crank and rods. All fastners are getting replaced with ARP master stud kit.
            New flat-tops and free floating conversion. Stock heads are getting reused until end of this year or early next year. Saving for the Trick Flows!!!
            This months purchases:
            Cam (EDL-7167) TC (FRPP M-6268-A460) ARP Main Stud kit (ARP-155-5402)
              OK, call me stupid, but what is a "free floating conversion" ?
                Instead of a press-fit wristpin attaching the piston to the connecting rod, you can convert some factory rods with bushings to a "full floating" wristpin style.
                '80 Town Coupé
                  Oh, and ditch those pile of shit heads.
                  Get some D0 castings, and work from there. Otherwise, you'd be wasting your time!
                    Super high compression with those beasts!
                      Aftermore research I am going to get these.
                      (Just go off the phone with one the local Ford guys.. He works here.)
                        Still good combustion chambers, compared to the D3 shits you got now....
                          The exhaust manifolds must look pretty nice after one of those cruises.
                          Nick
                          88 Colony Park LS
                          G-pa's old car, but he's cruisin around heaven in his 69 wagon now
                          Future plans:Semi HO conversion, or Explorer motor swap, shift kit, PI springs and sway bars, KYB-GR2 shocks
                            At least balence it.
                            Also, may want to look into dacking the block and heads, because that will yeild you the most compression with those horrible heads.
                            You want about 9.5-10:1, right?
                              They're water cooled. I can put my hands on them with the motor at full load. They never get over 180 degrees.
                              Yeah, balance it. Vibration is bad, mmmmkay? Looks like g-ma and g-pa didn't have thier coolant serviced regularly. Those freeze plugs are hardcore rotton. Make sure they remove those and the oil galley plugs when the block gets power washed that way all the garbage gets flushed out.
                                Oh yea, I am taking it in on a friday or saturday, and gettin them to let it soak all weekend! That outta do it!
                                Is there any real pluses with going with an aftermarket balancer vs. stocker?
                                Also what about knife-edging the crank? Never done that before, but I hear mixed messages about it. Any first hand experience around here?
