My cam is pretty small. 264/270 with 512 lift on both sides and a 114* lobe seperation. It will not idle with speed density. I have converted it to MAF with an 80mm MAF and 24lb injectors...I need to get it tuned. Tuning is a lot of $$. (~$550-$700)
You also need to consider the driveline when you start modding also...a good AOD with a stall converter will be about $1800-$2K. Gotta remember that it's not always about the HP, but how efficiently you use what you have. A good example of that is the super linc and my wagon, both have the exact same explorer long block, with the exception of cams. The lincoln has a wide ratio AOD, and mine has a stock trans....the lincoln is quicker off the line. I need to get a wide ratio when I can afford it.
