whenever i put my 88 vic into gear from park, it makes a loud hissing sound that sounds like it coming from the steering column, usually when i go into drive.. but if i take it out of drive and put it into overdrive or neutral, then back to drive, it will stop.. any ideas? it's only getting worse and worse and louder, is it a vacuum leak or what's the deal? anyone ever heard of this problem before?
also, my valve covers are leaking oil badly, are they a job to fix? someone said i could just use gasket sealer instead of replacing the gasket, but the gaskets probably aren't too expensive, but are they hard to change?
