Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
Thread: LED services and buy-in
  1. #41
    39,086
    The slip showed up Friday, and I picked them up and installed them today. 6 bulbs in the clusterfuck, one in the AC controls, one above the power antenna switch, 2 in the door. Not sure where I'm gonna put the other 2. Maybe I'll just use those for the bezels. I need some sort of way to stick the light sockets in the bezels tho first, and unfortunately my RTV-wiz can is on the boat.
  2. #42
    central VA
    12,773
    crap, I forgot to give you two sockets that fit the bezels.
    I have been using the kind that are the rear sidemarkers and front corner markers on boxes... just pulled a bunch from the yard. the sockets vary size a tiny bit so you may need to try a couple untill you get ones that will squeeze right in and stay.
  3. #43
    39,086
    I stole 2 from the doors on a townie. One fits snug, the other is loose. I was gonna just use some silicone or RTV or something and goop on there to make it watertight / hold the light socket.
