Special Tool For Removing Serpentine Belt
    I think that my waterpump may be failing. Is there a special tool to remove the serpentine belt? I have a long breaker bar but that does not quite reach. Also is the waterpump a pain to change on a 92 Grand Marquis?
    Hey I think you can use a 1/2" breaker bar to remove the belt, I used one to remove mine. The water pump has a "weep hole". If you see coolant "weeping" from this hole, then you need to replace your pump.....sorry.
    [img] waterpump.jpg [/img]Apparently I tried to send you a picture of it, but I am too computer illiterate to understand how to attach stuff.
    1993 GM LS 244K
    29.5mm PI front bar, ENS greaseable bushings, 21mm rear bar, ENS bushings, endlinks. Black steelies, center caps. Stewart-Warner mechanical oil pressure guage. K&N filter
    1994 Lincoln Mark VIII 144K
    All airbags are now coils/struts. Junk tranny, motor donor car
    Mercury Owners Group
    If you don\'t like what I have to type, don\'t read it. It is only my opinion, nothing more.
      If you need to host the pic, email the pic to me...
      hot_rod_linkin420@yahoo.com
      ill take care of it when I get home
      Also, a good serp belt tool is this flat breaker bar like object that gets into a confined space. I got one, they are awesome!
