Power steering pulley
    I searched and found the thread on removing pulley but how do you install it without beating the hellout of it?
    They usually come with an installation tool. Or you can rent one... Or use a nut, bolt, and washer. The shaft on the pump is threaded
      I went to napa and they rented me a installation tool,I installed the pulley,& then I saw a nut bolt and washer in box that p.s. pump came in. Now that I understand how it works Im a little embarassed I didnt figure it out.
        that's why were all here to helps fellow gmnr's out
          Just don't do like I did and bottom the bolt out and have it snap off. Was doing one on a boat and this happend when the pulley was about 3/4 of the way on there. I took a piece of wood and a hammer and smacked it the rest of the way on.
