need a picture of
    need a picture of
    a Map sensor for the 1982 EEC-III system. What does it look like and where is it. I think i know where it is, but im not quite sure if im looking at the right thing.
    I know its a vague post, but please bear with me.
    I think its on the passenger side fender and is a round thing but don't quote me on that. I've never worked on an EEC III car.
      Not round, they all look the same. rectangular, mounted vertically on the passenger side fender, towards the rear.
        Go here: http://198.208.187.182/internet/Part...rtnbr=213-1750
        Rockauto is a good source for parts, prices, etc - plus it has pictures!!!!
        HO with Explorer Cam, Electric Fan, Cop Sway Bars, Dual exhaust with no mufflers, 15x7" American Racing; 215/70R15's front, 255/60R15's rear, 3.55's with Trak-Lok.
          See, I toldya they were kind of round
            yah they are wierd lookin.
              Doesn't look like the one I just saw saturday on that car Johnnie stripped. That one looked just like the one on the SEFI cars.
                There is no MAP sensor. Just a B-MAP sensor. Just as i had expected. Thank you for the pic!!!
                  If RockAuto's info is correct, it looks like the round B-MAP sensor was used on 1983 and older only. Later cars (still CFI) got the newer style.
                    Thank you again guys. B-MAp is functioning properly. Disconnected it and the car would run so rich it would pour black smoke (heavy) out the tailpipe. Gonna try the crankshaft position sensor.
                      yeah, the one jonny stripped was an 85 - they are EEC-IV like yours
                        Most of the EEC IV CFI sensors are the same as SEFI stuff really. The only real difference is the actual injector system. EEC III stuff is just odd.
                          i've werked on eec3..............what's it doing?
                            its alot to explain.....i dont even know where to start.
                            Its a little late in my evening....(1024 am in the morning..i had a very VERY LATE NIGHT) Im gonna get some sleep and come back to try and explain whats going on. I have aim, so if you see me online please IM me.
                            SN is : DAILLMK7
                              ok heres a short run of whats going on with it.
                              no matter how cold or hot it is, WOT boggs down completely. in neutral it will rev to appx 3000, but beyond that will bogg and backfire in the air filter. Every mechanic almost that has come in contact with this car says its timing. The timing chain was done less than 2k miles ago. it was off 2 teeth. no it is corrected. timing or whatever it is still seems to be WAY the fuck off. I am so agrivated because its so georgous and i cant enjoy it. I have a decent amount of money into the car so i would preffer to drive it as almost a daily driver (it owes me that much)
                              what has been done:
                              fuel pump/filter/tuneup. Car holds pressure at the right PSI for fuel. Bmap is functioning. TPS is non functional. car also seems to be overheating???? i have a bad heater core and an extremely hard hose just mins after starting the engine. I will bypass the core and remove t-stat when i get a chance tomorrow most likely.
                              That wat the car is doing in a nutshell. i will get video of what happens on a WOT
