Results 1 to 13 of 13
Thread: {FOX PARTS}headers
    Default {FOX PARTS}headers
    does anyone know what headers will fit a 91 marquis and where to find them? thanks
    Pirate
    Guest
    Most of your Mustang 5.0 (both stock and aftermarket) shorty headers fit...but they require the Mustang H-pipe....the Marquis manifolds have the O2 sensor bungs in them, and they are in the H-pipe on the mustang exhaust...
    Fack da Hulk Hogan! Grand Marquis GT's Avatar
    Nov 1982
    Hamilton, AL/Little Rock AFB, AR
    19,463
    I saw you lookin!
    Welcome to GMN!
    Either stock or aftermarket mustang shorties will work. But you will have to modify the downpipes, because they are different. You have dual exhaust, I take it.
    Heres is a pic of the difference in the collectors, the shorties are on the top, manifolds on the bottom. (Thanks for the pic, justin!)
    Quote Originally Posted by sniper308 View Post
    Everybody have some of crazy the difference is that some have a little less and some have a little more, I have a little less combined with some of eccentric. :heyhey:
    ATT, SNIPER 308. " YOU HAVE TO BE MY EYES " Tomb Raider.
    Quote Originally Posted by DuceAnAHalf View Post
    this.
    if your letting your girlfriend run your life like that, congratulations your a bitch. grab my pocket, i just bought you for two packs of cigarettes.
    Pirate
    Guest
    Quote Originally Posted by grand_marquis_gt
    I saw you lookin!
    Welcome to GMN!
    And if you look close enough, you will see the face of Satan in the bottom manifold pipe opening...
    Nov 1982
    19,463
    Holy shit, I didnt notice that before! :hairrais:
    this.
    thanks for the help. theres not alot of places to go for info for these kinda cars. not alot of people like these type of cars.
    Pirate
    Guest
    Quote Originally Posted by 91mercruiser
    Well, there is a plethora of information here...
    Nov 1982
    19,463
    Thanks
    Yes we are the resident grand marq nuts
    this.
    Cheese Nazi phayzer5's Avatar
    Dunnellon/Gainesville, FL
    3,461
    so do my exhaust manifolds = $26,000 grilled cheese?
    '97 GMQ, 208k and counting
    '74 F100 Explorer, 351M-powered
    It's all about ME! monterey1962's Avatar
    North Dakota
    5,134
    A few questions:
    1. So, both Mustang 5.0 stock and H.O. headers match up to the H-pipe? There was only one type/shape of H-pipe available? I assume w/cats and w/o cats were the same shape/bend.
    2. Do the mustang headers bolt up to the stock GM heads? Does it make a difference in performance without the H.O. heads?
    3. I'm going to be looking at a cat-less H-pipe on Friday. Does it make a difference if the Mustang had a manual or automatic trans? I'm assuming not, but I want to make sure there is no difference in the shape or bend of the H-pipe.
    Justin
    My Name is Fudge Flapjack.
    588
    1. Yes, Catted or Cat-less H-pipes are the same bend. X-pipes are usually more tricky.
    2. Yes, they bolt up to standard (s.o.) heads. They still flow better than stock manifolds. You'll notice more top-end power as well as a better sound than with manifolds.
    3. H-pipes are usually for AOD's and X's, as I said, are usually for 5-speeds. Some have reported getting X's to work around AOD's but the H is the safest bet.
    North Dakota
    5,134
    Thanks.
    Justin
    Tremont PA.
    15,275
    if you are installing headers, i would get a set of aftermarket 1 5/8" unequal length shorty headers for a 86-93 mustang. the stock shorty headers are somewhat restrictive.
    if looking for a low cost option, pick up a set of tubular manifolds from a 1990 lincoln towncar.........they are only found on the 90 btw they are a direct fit and should offer a slight gain in flow
    oh and welcome to gmn!
    scott
