I have seen Toyota supras run over 1000 hp on them trannies...
seems like you would need to replace the first gear thrust washer or run shock proof oil if you gonna tear around on it.
I have heard that. I have some mags with supra's in there if I can find one I will post what the torque the are running is just so you can see if it would work or not
Its prolly alot better than a t5 but, you have to use the adapter bellhousing and I'll probably need a new drive shaft yoke to fit the r154.
I still want to use the t56, I might call around and see if I can find anything that will work.
Getting it to fit a 302 is the problem. Its also just a glorified automatic transmission, or "stick shift for idiots" as I tend to refer to them. Its for people who cant drive manual but want the control. Its a regurgitated modernized version of the manual valve body auto trans with a ratchet shifter. There are few new ideas in the automotive industry, most of them are just recycled old ideas.
