Last night when I went out with my friends I came up to a stop light in my car and the brake pedal went down to the floor. I checked the Master Cylinder and it was full. I pulled the vacuum line from the booster and plugged it and the brakes felt fine and tight. I did the brakes with all new lines and hoses a few years ago, they cant need bleeding already can they?
My question is, I have the original power brake booster, could it be going bad? When they fail, dont you just loose your power brakes? I know I probably should bleed the brakes but the front bleeder screws are siezed and I cant get them out. So I'd probably have to buy new calipers. I really wasnt planning on replacing them till I did the big brake upgrade this spring.
