Results 1 to 10 of 10
Thread: Dash Light / Climate Control Light
    The GMN Cowboy™ MrMarquis's Avatar
    Jul 2006
    York, PA
    3,616
    Default Dash Light / Climate Control Light
    Howdy; gots questions.
    Ever since I was hit, my dashboard gauge light and climate control console lighting will flicker in and out. I haven't checked the fuses yet, it may be a fluke...But I was just curious as to what y'all thought. Maybe a wire was knocked loose on impact?
    Another thing that started up. My Viper keyless entry and remote start system stopped working. I thought it was just the remote battery at first; but the locks are supposed to work automatically when I start and turn off the car...And they don't fire. I haven't a clue how the system is wired; so maybe someone would know if they are sensitive to collision shock?
    Thanks.
    3AG Swap, Dual exhuast with Cherry Bomb glasspacks, Ford Racing wires, TransGo Shift Kit, 98-02 Steering Box, 1 1/8" front sway bar, 1" rear bar, KYB Gas-A-Just shocks, cargo coils, 155lph fuel pump, train horns, CB radio, Trunk Muncher and more to come...
    - 1988 Mercury Grand Marquis LS - 1994 Ford F150 XL - 1949 Ford 8N - 2008 Chevy HHR 2LT
    Dave84
    Guest
    is there any kind of reset buttion do you know? and the dash light's im not to sure about
    panther lover forever gabegt90's Avatar
    Damascus Maryland
    5,269
    mine does that too sometimes when I'm driving at night the cluster will dim for a little bit I think it's because of my orgrinal altenator
    1989 mercury grand marquis gs / 1994 geo prizm lsi daily driver/work car
    Jul 2006
    York, PA
    3,616
    Quote Originally Posted by gabegt90
    It doesn't dim, it goes completely out; the dash and climate control...Can't see a damn thing when it does.
    I post a lot... nitroracer's Avatar
    Apr 2005
    Nottingham, PA
    2,103
    If its all the dash related lights you have a wiring problem in there. I had a problem with my old car that would lose power entirely on corners, no lights, engine, nothing. Ended up being bad battery cables.
    -Matt
    1968 Fairlane 500 - 1998 Camaro Z/28
    pickup man boXman's Avatar
    millville PA
    8,410
    Take out your headlight switch, I bet the plug is crispy.
    I replaced the plug on mine, cuz I had no dashlights an shit. Still had no dash lights, replaced the switch and now its good.
    '95 Ford Bronco XL -
    http://grandmarq.net/vb/image.php?type=sigpic&userid=39&dateline=125548186  3 :rebel:
    central VA
    11,985
    yup look at that. next time it happenes, go look to see if you have parking lights. if not, its prolly the switch or a wire for the parking lights getting pinched. Try wiggling/turning the headlight switch too.
    Photobucket Paul_'s Avatar
    Milton, NH
    9,234
    The headlight switch, and quite possibly the connector to the switch, are toast. Ford, in their infantile wisdom decided to route all the juice flowing through the lighting circuit into that switch.
    If you're lucky, the connector may not have gotten fried just yet, and you'll just have to replace the switch. I also highly reccomend that you install relays for the headlights. Doing this will help prevent issues later down the line.
    Save a seal, club a liberal.
    Jul 2006
    York, PA
    3,616
    Well...I had parking lights...
    So, I guess I have to go under the dash to get the headlight switch out?
    Paul...Would you have a diagram or a better explanation of the relays? I'm not the most electrically-inclined person...
    24,860
    Might also be able to fix it by simply removing and re-installing the bulb. Sometimes the connection on the bulb gets funny. Good idea to inspect the switch connections though just to be safe.
