they make lots of install kits, if you find one at walmart for our application it should work.
You dont HAVE to use one, but if you want it secire, use one.
I suggest buying a head unit from crutchfield.com, they give free install kits and wiring harnesses (you wont need the harness if you hard wire it)
do you have door speakers allready?? the holes in my doors are for 5 1/4", but they can be enlarged.
if you mount them directly to the metal inner door panel, then you'll certainly get rattles.
Also Im not sure about this, but if you dont have vent windows, the window rolling down my interfere with the speaker sticking out, if its a deep speaker.
The way I did mine, I used stock angled speaker baffles from newer boxes with premium sound and attached them to the outer door panel (the carpet and cardbaord part) and then put the speaker in the baffles. no rattles!
